Intake silencer removal help
Discussion in 'Modifications And Maintenance' started by imported_n/a, Sep 30, 2004.
  1. imported_n/a
    Online
    imported_n/a Guest
    Anyone want to hwlp me remove the intake silencer? This is my first new car and I am not overly mechanically gifted.
    I live in Hampton, 30 miles south of St. Paul on hwy 52. I would even be willing to come to you sometime
  2. bikerboy
    Sure what car?
    It is really easy, pull pasenger wheel
    pull back inner fender
    locate nut inside inner fender holding bottom of silencer and remove
    open hood
    look for nut between the two holes on the passenger side and remove
    pull inner fender back again and remove offending piece
  3. Musashi
  4. BlackDubRX
    BlackDubRX New Member
    Paul, don't worry, pulling the intake silencer out of my WRX was the first thing I did and I didn't have instructions. It'll take less than 20 minutes if you know what's what on your car.
  5. zapman
    zapman Well-Known Member
    Just don't follow the instructions from import tuner. they took off the head light and bumper....
    You can do it without taking the wheel off, its just a little more cramped. I've done it twice to my car. I got in an acciedent which tore off my passenger side front panel, and it was gone so they put a new one on.
    When I've done it i hack off the big conatiner at the bottom and keep top that connects to the ram and the airfilter box just to the intake is always getting a fresh supply of air and nothing wiggles around.
