Intakes on MAF imprezas
Discussion in 'Modifications And Maintenance' started by Dynapar, Jun 9, 2004.
  1. Dynapar
    I have been loking for intake for my 95 for a while and they are easy to make / find but i need an adapter for the MAF unit. it will fit right over the intake tube, but i need to fabricate a adapter for a conical filter to a rectangular bolt pattern. does any one have any experience with this. by the way i can buy the part but its $30 for the POS
  2. bikerboy
    Your talking about the old style MAF with the flapper door? Sounds like it from your description, HKS makes an adaptor that works.
    M
  3. RallyNavvie
    RallyNavvie Well-Known Member
    I had a 96 with hot-wire MAF sensor in the intake, the 95 isn't the same?
  4. Todd
    Todd The Originator Staff Member
    The last "Flapper Door" MAF on a Subaru was in 1987.
  5. Dynapar
    it just that there is an odd shaped coupler that connects the actual intake to the air box, i can replace the intake but to remove the air box i will need an adapter that will allow it to mate with conical filter.
