iPod hook up question
Discussion in 'General Subaru Discussion' started by ndejulio, Oct 28, 2011.
  1. ndejulio
    ndejulio Member
    Hey guys, name is Nick and I am new to board. Just bought a 2008 Impreza. This is my first Subaru. Last 12 years I have been in the VW camp. Well anyway, the car did not come with an MP3 jack. Does anyone have a kit that they recommend that is tied into the factory head unit?
    Thanks,
    Nick
  2. webcrawlr
    webcrawlr Well-Known Member
  3. austinpike
    austinpike Well-Known Member
    ^^^ Jazzy kit is for 02-06, not 08.
    You have a CD/aux button on your headunit, correct? It just doesn't switch to aux?
    There is an 8-pin port on the back that has the aux-in. Subaru sells a kit for ~$60 that plugs into that. H6210FG000
    If you can find some connectors to fit onto those little pins, you can make your own for a couple bucks. (only 4 pins are used)
    http://forums.nasioc.com/forums/showthread.php?t=1601285
    Otherwise there may be a couple guys on nasioc who sell home-made cables with the correct 8-pin harness.
    If you want full iPod integration with the headunit, Subaru sells a module for that too. H621SSC201
    Can be found used on NASIOC for ~$100
    http://forums.nasioc.com/forums/showthread.php?t=2254300 (no affiliation with seller.)
