Is this noise familiar with anyone? Update: Short Block being replaced by Subaru
Discussion in 'Modifications And Maintenance' started by Chaotic Yeti, Oct 21, 2013.
  1. Chaotic Yeti
    Chaotic Yeti Well-Known Member
    Hey all,
    I recently had an oil change and noticed a new sound. At first it was quieter and only seemed to happen at part throttle. Now it seems to happen randomly along the rpm range while driving, but never at 50% or more throttle. It kinda sounds like something rattling around. I removed a piece of the oem heatshield that did feel a little loose (the smaller underside from the stock turbo heatshield I replaced with a cobb), but the sound persists. The clip is after the loss heatshield section was removed. Nothing else felt loose, or prone to rattle.
    Fear of knock or some other catastrophic thing is pushing me to ask for opinions before I bring it in.
    Cobb Stage 2 map (nuke tweak), full tbe, cobb intake, turbosmart 100% recirc valve.
    edit: yes, I woke up to my tires being low this morning :).
  2. Chaotic Yeti
    Been doing some research. Seems like it could be a noisy lifter.
    Update: Wrong
  3. Chaotic Yeti
    Took it down to my local Firestone. Mechanic there seems to concur that this could be the issue. The manager was afraid of doing any internal work on the engine, but after talking it through it looks like they are going to give me an estimate for replacing the driver side HLA's.
    They changed the oil again for free as well.
  4. Chaotic Yeti
    Firestone turned it down because the tech was not comfortable enough with it. Morries is next on the list.
  5. BroCo
    BroCo Moderator Staff Member
    Contact NF Performance.
    Chaotic Yeti and tehfuzz like this.
  6. Chaotic Yeti
    Gonna get an estimate from Morries. I am sure it will be high. I wanted to have a starting point before I talk to NF.
  7. kongzilla
    kongzilla Well-Known Member
    Easier and a lot cheaper to go to the people who eat, sleep, and breath Subaru.
    Do I need to mention who they are? They sort of dominate this forum.
    Chaotic Yeti likes this.
  8. Chaotic Yeti
    Haha, yeah, I know. Just doing a little due diligence myself.
  9. Kevin Harrington
    Kevin Harrington Member
    We'll the first problem here is your video is not working for me... Probably my phone. Next problem is you have Firestone do your work...
    Please don't ever again ask a firestone to engine work. Unless of course you know that Firestone has a seasoned veteran tech. Which 99% of them do not.
  10. Chaotic Yeti
    I didn't have Firestone do work on my engine. I asked them for their opinion and estimate. They suggested I take it to a dealer or a performance shop. I have a good relationship with my local Firestone and they are within walking distance from my home. I'm not going to stop asking them for estimates and opinions when something comes up. Why wouldn't I ask them if they can do it? I trust their lead tech, and if he said he wanted to do it, it would get done. He said he wasn't comfortable trying since he hadn't done it before and wasn't sure how accurate his estimate could be. No harm no foul.
    idget likes this.
  11. Kevin Harrington
    Like I said, Unless you know that Firestone has a good tech. I was mostly giving you ****, and it was late when u posted that. But seriously there are lots of guys on here that have taken apart tons on subie engines and charge less than a shop.
  12. Chaotic Yeti
    Yep. Going by distance, and working my way out. The quote from Morries was pretty funny.
    Update: This was the Brooklyn Park Morries Subaru, and was an over the phone quote.
  13. Kevin Harrington
    No yeah, Morries will get the job done but it will be expensive. Message nf and have them give you a quote.
  14. Chaotic Yeti
    Already messaged. I've met the gang, and they are all top notch.
  15. Kevin Harrington
    Cool man, good luck and keep
    Posting here if you need more help. If it comes down to it I can do it but i would be doing it in my garage hence I would take longer....
  16. Chaotic Yeti
    Have you done this before?
  17. Kevin Harrington
    Yes but not nearly as much as the guys at nf,
  18. Chaotic Yeti
    But, you've dealt with this specific issue?
  19. Kevin Harrington
    Umm no. I have done head work and engine work, but I have never torn one down for the Lifter issue yet.
  20. Chaotic Yeti
    Took it to NF so Nuke could have a listen. Nuke is confident it is a spun bearing. I will update when I get this worked out.
  21. Nhibbs
    Nhibbs Well-Known Member
    Bummer man :(
  22. spudd
    spudd Well-Known Member
    definitely sounds like a rod knock. p.s. your car doesnt have hydraulic lifters, they are solid buckets. hopefully you dont have too much metal going through your engine and the cam journals arent scored
  23. Ronnie@RSmotors
    Must be the same car I saw today.
  24. tehfuzz
    tehfuzz Well-Known Member
    is that the silver 09 hatch I saw there last wed?
  25. Chaotic Yeti
    Probably, yes.
    Dropped it off yesterday at Minnetonka Subaru. I have 3 months left on the original Subaru powertrain warranty. I will know more later today.
  26. tehfuzz
    That was me you talked to. was having my 08 wrx sedan getting upgraded.
    hope you find the resolution you need, and that it isnt too pricey :unsure:
  27. DIRTY D
    DIRTY D Well-Known Member
    sorry to hear that my 09 had it happen at 30,000 miles. What is the build date if you do not mind me asking??? 08/09 of 08???
  28. Chaotic Yeti
    Hey, I remember you. How is the 08? They will fix it either way, I just hope it is covered under warranty.
  29. Chaotic Yeti
    Thanks, man. Not sure when it was built. I've been reading up on this. Not an entirely uncommon issue. I am right around 57,000 miles.
  30. Chaotic Yeti
    Just got off of the phone with Mike at Minnetonka Subaru. He said they are in my corner as much as possible, but they aren't going to cover anything that wasn't caused by a faulty/failed Subaru part. I am on board for the initial $99.95 diagnostic fee, and they are moving forward with tearing down the engine (another $1,290.00). I haven't paid anything yet, and these costs will be covered under the warranty if it meets the criteria. Mike said I should know more by Monday afternoon.
    Not sure how many people care. I just hate threads where someone has an issue/question and the last thing they post is that it was fixed without any explanation. Hopefully this helps someone else at some point.
    JuStaWRX, idget, TMF and 1 other person like this.
  31. tehfuzz
    It still runs like a dream. picked up a used anarchy motive shift knob from one of the other members hear and it shifts like a dream now. so happy i got rid of the stock knob. had the boost controller and downpipe put on. will say there is a mega difference between stage 2 and a stock tune.not bad for only being on 16.5 psi with a stock turbo
  32. Kevin Harrington
    I totally agree man. More info is great that way other people on the forum can get their cars fixed too
    iand464 and Chaotic Yeti like this.
  33. Nhibbs
    Agreed, need more threads with clear conclusions. Can't count the times I have found a post by someone who has the exact same problem or question I have only to find no resolution or answer.
    Hope it is covered by warranty! If it is, you are lucky it took a crap right before the warranty ran out.
  34. TMF
    Yup, thanks for keeping us updated. Best of luck and sorry to hear this happened.
  35. Chaotic Yeti
    Ok gang, ready for an update? I got a call from Mike at the Minnetonka Subaru. The short block has major scoring in all cylinders, especially 2,3,4. I just about ****ted my heart out waiting for him to tell me what it was gonna cost me. Subaru is going to replace it with a brand new short block at no cost to me. Covered under 'Good Will' of the original Subaru powertrain warranty. Christmas come early. I should get a call back here shortly as Mike is looking into the timing of ordering parts and such. I am relieved.
  36. Schikane
    Schikane Active Member
    I'm sure that was a heavy weight off your shoulders.
  37. tehfuzz
    Glad to hear everything worked out for you!!!
  38. Chaotic Yeti
    Thanks, man. Everything is going good so far. I am sitting at just under 60k, so while everything is out I'm replacing the clutch as well. Also gonna see if they'll put in the killer B pickup I ordered.
    tehfuzz likes this.
  39. 02_Rexxxy
    02_Rexxxy Active Member
    And then people wonder why people buy extended warranties! Good thing everything worked out good for you.
  40. TMF
    Glad to hear that things are working out as well. +1 for the Killer B oil pickup.
  41. Chaotic Yeti
    Just heard from Mike again. The Subaru district rep had come by again to take pictures. He confirmed to Mike that they were not requiring me to go back to stock, and will be putting my tbe, intake, etc back on. I had the OEM parts ready to go in case that was going to be a requirement for the new short block. This has been a much smoother process than I had anticipated. Kudos to Mike and the boys at Minnetonka Subaru for walking me through this, and to Nuke at NF for pointing me in the right direction.
    Update: Just got a call back from Mike. They are going to pay for a couple days on a Hertz for us as well. Needed an extra vehicle for commutes, but wasn't expecting the generosity.
    Schikane and tehfuzz like this.
  42. Chaotic Yeti
    I was able to snap a few quick pics when I went in to pick up the rental car. The tech had already gone home for the day, and they didn't want me to touch anything so the relevancy of these pics are in question. Not that I wanted to mess up the tech's work area, either.
    Schikane likes this.
  43. Schikane
    Cool pics!
  44. Erik
    Erik Well-Known Member
    Did you have an extended warranty through Morries, or just the factory warranty? It sounds like from your post that it was the factory warranty, but then another OP said good thing you have the extended warranty.
  45. ShortytheFirefighter
    Mike is one of the few reasons I miss owning a Subaru, he's one of the better service writers I've gotten to work with over the years as a customer. All of the guys at Mtka Subaru are solid to work with, but Mike was probably my favorite. Good luck, glad to see you're getting taken care of.
