Just recently got the car tuned, and everything seemed right, but after awhile of driving around, when the car was in 5th gear and slowly accelerated it started to cut off, like something was opening up and releasing or something shutting off ignition or fuel wise; can't find a boost leak, doesn't seem to be a boost leak, and everything seems to be tight. I am clueless at this moment on what it may be. Help Umm noticed a lil bit of oil on the maf sensor, wondering if that could be throwing things off, but it didn't seem like anything serious too much but dont know how sensitive it is. When I shift, it feels dead at a moment, like no boost/power and I am pretty sure it's boosting but than it suddenly goes full boost. Any ideas??????
Mods: Kazz geared tranny w/ exedy clutch external wastegate, vf34 turbo sti injectors, utec, gt spec headers, front mount, full exhaust, bigger fuel pump, there's always more but i always forget, but this is to name a few. ::But keep in mind for the 1st lil bit it was still running decent/good, now it is running weird like i stated::
I say run a can of SeaFoam through your car and see if it was clogged injectors, and maybe a new fuel filter. Also, check your vacum lines. And again, a log would help a lot.
We think our Maf sensor is reading wrong; oil in intake, trying to clean that out. There shouldn't be a boost leak. And the injectors are new, should be clogged.
i just got done re-tightening everything that could possibly leak... im going to go out and do some pulls and ill try to post the logs in a bit....
How would i go about hosting a *.TXT file on the net for you guys to view? I can E-mail the log to any1 who wants to look it over.
this is getting up to 5th gear at about 60mph andthen holding it to the floor... i will post another one here shortly.. [1;24r[0m[2J[01;05H[0m[4mLOGGER[0m[01;44H[0m[4mTURBOXS UTEC (Version 4.2c) (c) 2004[0m[03;05HTo log this data use the 'CAPTURE' function in HyperTerminal(tm)[24;01H[7m <CTRL-x> : Exit to Main : Pause <s> : Start <space> : Toggle [0m[05;01H [06;01H RPM TPS MAP MLP MOD AFR KNOCK [07;01H % psia IGN COUNT [9;21r[10;01H0715 000 -9.6 00 ECU. 14.8 00000 0725 000 -9.8 00 ECU. 14.8 00000 0734 000 -9.8 00 ECU. 14.8 00000 0726 000 -9.8 00 ECU. 14.8 00000 0698 000 -9.8 00 ECU. 14.9 00000 0742 000 -9.6 00 ECU. 14.8 00000 0756 000 -9.6 00 ECU. 14.7 00000 0746 000 -9.6 00 ECU. 14.7 00000 0753 000 -9.8 00 ECU. 14.8 00000 0735 000 -9.8 00 ECU. 14.6 00000 0688 000 -9.8 00 ECU. 14.5 00000 0737 000 -9.8 00 ECU. 14.6 00000 0724 000 -9.8 00 ECU. 14.7 00000 0745 000 -9.6 00 ECU. 14.8 00000 0740 000 -9.6 00 ECU. 14.8 00000 0720 000 -9.6 00 ECU. 14.8 00000 0920 000 -9.1 00 ECU. 14.8 00000 0920 000 -8.7 00 ECU. 14.4 00000 1381 004 -7.9 00 ECU. rich 00000 1317 004 -6.9 00 ECU. 13.5 00000 0576 004 -5.9 00 ECU. 16.2 00000 0000 000 -4.5 00 ECU. 13.8 00000 0000 000 -4.5 00 ECU. 14.6 00000 0000 000 -5.7 00 ECU. rich 00000 0000 001 -7.3 00 ECU. rich 00000 1830 001 -9.1 00 ECU. rich 00000 1873 001 -9.8 00 ECU. rich 00000 1607 001 -9.4 00 ECU. rich 00000 1341 010 -8.1 00 ECU. rich 00000 1474 010 -6.5 00 ECU. rich 00000 1376 011 -4.9 00 ECU. rich 00000 1094 011 -3.0 00 ECU. rich 00000 1346 015 -2.2 00 ECU. rich 00000 1438 015 -2.0 00 ECU. rich 00000 1570 015 -1.8 00 ECU. 12.1 00000 1751 015 -1.8 00 ECU. 12.2 00000 1926 015 -2.0 00 ECU. 12.0 00000 2115 016 -2.0 00 ECU. rich 00000 2275 015 -2.0 00 ECU. rich 00000 2456 015 -2.2 00 ECU. rich 00000 2610 015 -2.2 00 ECU. rich 00000 2787 015 -2.4 00 ECU. rich 00000 2989 015 -2.6 00 ECU. rich 00000 3153 015 -2.6 00 ECU. rich 00000 3320 015 -2.6 00 ECU. rich 00000 3486 014 -3.0 00 ECU. rich 00000 3631 014 -3.0 00 ECU. rich 00000 3783 013 -3.4 00 ECU. rich 00000 3360 000 -4.9 00 ECU. rich 00000 2918 000 -6.9 00 ECU. 12.2 00000 2600 000 -9.1 00 ECU. 13.0 00000 2832 008 -10.6 00 ECU. rich 00000 2670 008 -9.8 00 ECU. 13.4 00000 2844 017 -7.9 00 ECU. 12.0 00000 2903 017 -5.3 00 ECU. rich 00000 3000 017 -3.6 00 ECU. rich 00000 3103 017 -2.6 00 ECU. rich 00000 3214 017 -2.0 00 ECU. rich 00000 3320 017 -2.0 00 ECU. rich 00000 3401 017 -1.8 00 ECU. rich 00000 3505 017 -1.6 00 ECU. rich 00000 3615 017 -1.6 00 ECU. rich 00000 3707 017 -1.4 00 ECU. rich 00000 3822 015 -1.4 00 ECU. rich 00000 3916 015 -1.6 00 ECU. rich 00000 3987 014 -1.8 00 ECU. rich 00000 3724 000 -2.8 00 ECU. rich 00000 3494 000 -5.3 00 ECU. 13.1 00000 3086 000 -7.9 00 ECU. rich 00000 2681 000 -10.4 00 ECU. 14.4 00000 2918 004 -11.4 00 ECU. 13.7 00000 2931 004 -10.8 00 ECU. 12.4 00000 2955 012 -9.8 00 ECU. 14.1 00000 2978 013 -7.5 00 ECU. 13.5 00000 3027 014 -5.9 00 ECU. 12.7 00000 3052 014 -4.5 00 ECU. 13.5 00000 3080 014 -3.4 00 ECU. 14.1 00000 3124 014 -3.2 00 ECU. 14.3 00000 3180 014 -3.0 00 ECU. 14.7 00000 3202 014 -3.0 00 ECU. 14.7 00000 3245 014 -2.8 00 ECU. 14.4 00000 3313 014 -2.6 00 ECU. 14.5 00000 3326 014 -2.6 00 ECU. 14.5 00000 3363 014 -2.4 00 ECU. 14.6 00000 3411 014 -2.4 00 ECU. 14.5 00000 3457 014 -2.4 00 ECU. 14.4 00000 3486 014 -2.4 00 ECU. 14.6 00000 3538 014 -2.4 00 ECU. 14.5 00000 3591 014 -2.4 00 ECU. 14.4 00000 3642 014 -2.6 00 ECU. 14.4 00000 3667 014 -2.8 00 ECU. 14.4 00000 3691 013 -2.8 00 ECU. 14.5 00000 3394 000 -4.7 00 ECU. rich 00000 3080 000 -7.1 00 ECU. rich 00000 2602 000 -9.4 00 ECU. 12.1 00000 2849 007 -10.8 00 ECU. 14.7 00000 2761 007 -10.2 00 ECU. 12.4 00000 2773 013 -8.1 00 ECU. 13.9 00000 2763 013 -5.9 00 ECU. 12.2 00000 2808 015 -4.5 00 ECU. 13.1 00000 2824 014 -3.4 00 ECU. 13.7 00000 2832 014 -2.8 00 ECU. 14.0 00000 2856 004 -2.8 00 ECU. 14.3 00000 2861 004 -4.0 00 ECU. rich 00000 2861 004 -5.7 00 ECU. 13.7 00000 2858 004 -7.3 00 ECU. 15.1 00000 2871 004 -8.5 00 ECU. 15.2 00000 2853 004 -8.7 00 ECU. 14.7 00000 2858 004 -8.7 00 ECU. 14.3 00000 2921 004 -8.7 00 ECU. 14.1 00000 2866 005 -8.7 00 ECU. 14.6 00000 2918 004 -8.7 00 ECU. 14.5 00000 2866 004 -8.7 00 ECU. 14.3 00000 2858 007 -8.5 00 ECU. 14.7 00000 2873 007 -8.1 00 ECU. 14.9 00000 2881 007 -7.7 00 ECU. 14.1 00000 2881 007 -7.3 00 ECU. 14.2 00000 2858 007 -7.1 00 ECU. 14.4 00000 2908 007 -7.1 00 ECU. 14.6 00000 2888 007 -7.1 00 ECU. 14.5 00000 2908 007 -7.1 00 ECU. 14.5 00000 2918 008 -6.9 00 ECU. 14.8 00000 2944 011 -6.5 00 ECU. 14.9 00000 2934 012 -5.9 00 ECU. 14.4 00000 2929 013 -5.3 00 ECU. 14.1 00000 2973 013 -4.5 00 ECU. 14.4 00000 2997 013 -3.6 00 ECU. 14.7 00000 3027 014 -3.2 00 ECU. 14.3 00000 3044 013 -2.8 00 ECU. 14.4 00000 3060 014 -2.6 00 ECU. 14.7 00000 3077 013 -2.6 00 ECU. 14.3 00000 3075 013 -2.6 00 ECU. 14.1 00000 3089 013 -2.6 00 ECU. 14.6 00000 3144 013 -2.6 00 ECU. 14.7 00000 3147 013 -2.6 00 ECU. 14.5 00000 3171 013 -2.8 00 ECU. 14.6 00000 3205 013 -2.8 00 ECU. 14.6 00000 3198 013 -2.8 00 ECU. 14.7 00000 3223 013 -2.6 00 ECU. 14.6 00000 3264 014 -2.8 00 ECU. 14.3 00000 3293 013 -2.6 00 ECU. 14.4 00000 3293 013 -2.4 00 ECU. 14.3 00000 3300 014 -2.4 00 ECU. 14.4 00000 3350 014 -2.2 00 ECU. 14.4 00000 3390 028 -1.6 00 ECU. 15.1 00000 3408 037 -0.8 00 ECU. 12.5 00000 3397 046 +0.6 00 ECU. 13.7 00000 3468 049 +2.3 00 ECU. 14.1 00000 3472 051 +3.9 00 ECU. rich 00000 3531 052 +5.7 00 ECU. rich 00000 3538 052 +7.6 00 ECU. rich 00000 3646 052 +10.2 00 ECU. rich 00000 3639 052 +13.5 00 ECU. rich 00000 3703 052 +16.1 00 ECU. rich 00000 3818 052 +18.2 00 ECU. rich 00000 3862 051 +18.8 00 ECU. rich 00000 3982 050 +19.0 00 ECU. rich 00000 3907 050 +19.4 00 ECU. rich 00000 4040 051 +19.2 00 ECU. rich 00000 4045 051 +19.6 00 ECU. rich 00000 4161 051 +19.6 00 ECU. rich 00000 4203 051 +19.6 00 ECU. rich 00000 4368 051 +19.6 00 ECU. rich 00000 4351 051 +19.6 00 ECU. rich 00000 4468 050 +19.2 00 ECU. rich 00000 4474 050 +19.0 00 ECU. rich 00000 4553 050 +18.6 00 ECU. rich 00000 4278 000 +16.8 00 ECU. rich 00000 4312 000 +10.6 00 ECU. rich 00000 3982 000 +3.7 00 ECU. 13.8 00000 3531 000 -3.2 00 ECU. 24.5 00000 3100 000 -8.1 00 ECU. 24.2 00000 2718 000 -8.7 00 ECU. 24.5 00000 2329 000 -8.9 00 ECU. 24.2 00000 1961 000 -8.7 00 ECU. 24.2 00000 1628 000 -8.7 00 ECU. 24.2 00000 1289 000 -8.3 00 ECU. 24.2 00000 1597 000 -8.1 00 ECU. 24.2 00000 1773 000 -8.1 00 ECU. 13.3 00000 2313 000 -7.1 00 ECU. 12.0 00000 2482 000 -7.5 00 ECU. rich 00000 2237 000 -8.9 00 ECU. rich 00000 2031 000 -9.6 00 ECU. rich 00000 2057 000 -11.4 00 ECU. rich 00000 2344 000 -11.6 00 ECU. rich 00000 2787 000 -11.4 00 ECU. rich 00000 3069 000 -11.4 00 ECU. 12.0 00000 3069 000 -11.6 00 ECU. 12.1 00000 3030 000 -11.8 00 ECU. 12.2 00000 3013 000 -12.0 00 ECU. 12.5 00000 2997 001 -11.8 00 ECU. 12.5 00000 2992 000 -11.4 00 ECU. 13.1 00000 2965 002 -11.2 00 ECU. 14.6 00000 2968 005 -10.8 00 ECU. 15.1 00000 2970 014 -9.6 00 ECU. 14.2 00000 2955 020 -7.7 00 ECU. 14.9 00000 2968 022 -5.5 00 ECU. 13.6 00000 2947 028 -3.4 00 ECU. 14.5 00000 2989 033 -1.8 00 ECU. 14.3 00000 3003 040 -0.8 00 ECU. 13.8 00000 2973 043 +0.2 00 ECU. 14.8 00000 3011 043 +1.5 00 ECU. 12.4 00000 3013 044 +2.7 00 ECU. rich 00000 3011 044 +3.7 00 ECU. rich 00000 3038 044 +4.7 00 ECU. rich 00000 3044 044 +5.7 00 ECU. rich 00000 3089 044 +7.2 00 ECU. rich 00000 3100 044 +8.6 00 ECU. rich 00000 3189 043 +10.4 00 ECU. rich 00000 3162 043 +12.5 00 ECU. rich 00000 3156 043 +14.3 00 ECU. rich 00000 3208 043 +16.4 00 ECU. rich 00000 3205 043 +17.6 00 ECU. rich 00000 3226 043 +18.2 00 ECU. rich 00000 3394 043 +18.6 00 ECU. rich 00000 3330 043 +18.6 00 ECU. rich 00000 3310 042 +18.6 00 ECU. rich 00000 3350 042 +18.4 00 ECU. rich 00000 3483 042 +18.4 00 ECU. rich 00000 3443 055 +18.4 00 ECU. rich 00000 3483 094 +18.4 100 +14.0 rich 00000 3623 094 +18.6 100 +14.0 rich 00000 3572 094 +18.8 100 +14.0 rich 00000 3561 093 +18.8 100 +14.0 rich 00000 3711 094 +19.4 100 +14.0 rich 00000 3720 094 +19.2 100 +14.0 rich 00000 3720 094 +19.4 100 +14.0 rich 00000 3695 094 +19.4 100 +14.0 rich 00000 3707 094 +19.0 100 +14.0 rich 00000 3775 094 +19.2 100 +14.0 rich 00000 3862 094 +19.0 100 +15.0 rich 00000 3885 093 +19.2 100 +14.8 rich 00000 3912 093 +19.8 100 +15.2 rich 00000 3944 093 +20.0 100 +15.4 rich 00000 4030 093 +20.0 100 +15.6 rich 00000 4035 094 +20.0 100 +16.1 rich 00000 4060 093 +19.8 100 +16.2 rich 00000 4040 094 +19.6 100 +16.4 rich 00000 4120 092 +20.0 100 +16.5 rich 00000 4295 093 +19.8 100 +16.8 rich 00000 4295 093 +19.2 100 +17.0 rich 00000 4268 094 +19.2 100 +17.0 rich 00000 4301 093 +19.0 100 +17.0 rich 00000 4438 093 +19.2 100 +17.0 rich 00000 4391 094 +19.4 100 +17.0 rich 00000 4456 093 +19.6 100 +17.0 rich 00000 4486 093 +19.6 100 +17.0 rich 00000 4516 092 +19.6 100 +17.2 rich 00000 4610 092 +19.8 100 +17.0 rich 00000 4566 093 +20.0 100 +17.6 rich 00000 4616 092 +20.0 100 +17.6 rich 00000 4681 090 +19.8 100 +17.8 rich 00000 4675 089 +20.2 100 +18.6 rich 00000 4796 089 +20.0 100 +18.6 rich 00000 4768 089 +19.8 100 +19.4 rich 00000 4844 088 +19.6 100 +19.6 rich 00000 4810 088 +19.0 100 +19.7 rich 00000 5020 087 +19.0 100 +19.4 rich 00000 5042 087 +19.0 100 +19.8 rich 00000 4975 086 +19.2 100 +20.2 rich 00000 5128 086 +19.6 100 +20.2 rich 00000 5136 086 +19.4 100 +20.3 rich 00000 5096 086 +19.6 100 +20.7 rich 00000 4714 000 +16.8 00 ECU. rich 00000 4734 000 +9.8 00 ECU. rich 00000 4230 000 +2.9 00 ECU. 14.2 00000 3732 000 -4.7 00 ECU. 24.5 00000 3330 000 -8.9 00 ECU. 24.0 00000 2883 000 -9.4 00 ECU. lean 00000 2508 000 -9.4 00 ECU. 24.5 00000 2151 000 -8.9 00 ECU. 24.2 00000 1797 000 -8.9 00 ECU. 24.5 00000 1446 000 -8.7 00 ECU. 24.2 00000 1230 000 -8.1 00 ECU. 24.0 00000 1567 000 -7.9 00 ECU. 23.7 00000 1571 000 -8.3 00 ECU. rich 00000 1374 000 -8.7 00 ECU. rich 00000 1191 000 -9.8 00 ECU. rich 00000 0985 000 -10.4 00 ECU. rich 00000 0752 000 -10.4 00 ECU. rich 00000 0673 000 -9.8 00 ECU. rich 00000 0854 000 -8.7 00 ECU. rich 00000 0974 000 -7.9 00 ECU. rich 00000 1008 000 -7.7 00 ECU. rich 00000 0947 000 -8.1 00 ECU. rich 00000 0862 000 -8.7 00 ECU. rich 00000 0900 000 -8.9 00 ECU. rich 00000 0886 000 -8.9 00 ECU. rich 00000 0888 000 -8.9 00 ECU. 12.2 00000 0895 000 -8.9 00 ECU. 12.1 00000 0872 000 -9.1 00 ECU. 12.9 00000 0811 000 -9.4 00 ECU. 13.8 00000 0830 000 -9.1 00 ECU. 14.1 00000 0794 000 -9.1 00 ECU. 14.7 00000 0762 000 -9.1 00 ECU. 15.0 00000 0745 009 -8.7 00 ECU. 15.1 00000 1654 000 -7.1 00 ECU. 14.9 00000 2005 000 -7.1 00 ECU. 14.2 00000 1640 000 -7.5 00 ECU. 16.1 00000 2300 005 -6.9 00 ECU. 22.1 00000 2568 000 -8.9 00 ECU. rich 00000 2178 000 -10.0 00 ECU. rich 00000 2080 008 -10.0 00 ECU. 12.7 00000 2485 000 -10.8 00 ECU. 12.5 00000 2191 000 -11.2 00 ECU. rich 00000 1991 003 -10.8 00 ECU. 12.4 00000 1936 000 -11.2 00 ECU. 12.6 00000 1567 000 -11.8 00 ECU. rich 00000 1791 000 -10.2 00 ECU. 14.2 00000 2018 000 -10.0 00 ECU. rich 00000 1882 001 -9.6 00 ECU. rich 00000 1953 001 -8.7 00 ECU. 12.1 00000 2413 002 -9.6 00 ECU. 12.4 00000 2465 002 -9.6 00 ECU. 14.0 00000 2456 004 -9.6 00 ECU. 14.1 00000 2456 005 -9.1 00 ECU. 14.5 00000 2434 006 -8.9 00 ECU. 14.6 00000 2436 006 -8.1 00 ECU. 14.8 00000 2431 006 -7.3 00 ECU. 14.3 00000 2452 012 -6.7 00 ECU. 14.6 00000 2483 013 -5.7 00 ECU. 14.6 00000 2489 017 -4.5 00 ECU. 14.5 00000 2478 021 -3.2 00 ECU. 14.6 00000 2491 026 -2.2 00 ECU. 14.7 00000 2532 034 -1.4 00 ECU. 14.3 00000 2511 043 -0.4 00 ECU. 13.6 00000 2515 049 +0.4 00 ECU. 15.0 00000 2556 054 +1.1 00 ECU. rich 00000 2531 060 +1.7 00 +17.0 rich 00000 2594 062 +2.1 20 +17.0 rich 00000 2618 062 +2.7 20 +17.0 rich 00000 2592 069 +3.1 20 +17.0 rich 00000 2675 082 +3.7 30 +17.0 rich 00000 2681 094 +4.1 30 +17.0 rich 00000 2707 094 +4.5 30 +17.0 rich 00000 2754 094 +4.9 30 +17.0 rich 00000 2789 094 +5.5 40 +17.0 rich 00000 2743 094 +6.2 40 +17.0 rich 00000 2832 094 +7.0 40 +17.0 rich 00000 2873 094 +8.0 50 +16.0 rich 00000 2908 094 +9.0 60 +16.0 rich 00000 2973 094 +9.8 60 +16.0 rich 00000 2929 094 +11.0 70 +15.0 rich 00000 2970 094 +12.3 70 +15.0 rich 00000 3035 094 +13.9 80 +14.0 rich 00000 3153 094 +15.7 100 +14.0 rich 00000 3141 093 +17.0 100 +14.0 rich 00000 3297 093 +18.2 100 +14.0 rich 00000 3340 093 +19.2 100 +14.0 rich 00000 3293 092 +19.4 100 +14.0 rich 00000 3387 094 +19.4 100 +14.0 rich 00000 3422 093 +20.0 100 +14.0 rich 00000 3483 093 +19.8 100 +14.0 rich 00000 3425 094 +19.6 100 +14.0 rich 00000 3531 093 +19.6 100 +14.0 rich 00000 3623 093 +19.2 100 +14.0 rich 00000 3650 094 +19.0 100 +14.0 rich 00000 3639 093 +19.0 100 +14.0 rich 00000 3732 092 +19.4 100 +14.0 rich 00000 3805 092 +19.2 100 +14.4 rich 00000 3835 091 +19.4 100 +14.4 rich 00000 3875 091 +19.6 100 +15.0 rich 00000 3898 090 +20.0 100 +15.0 rich 00000 3930 090 +20.4 100 +15.4 rich 00000 3996 090 +20.2 100 +15.8 rich 00000 4079 090 +20.2 100 +16.1 rich 00000 4095 089 +20.0 100 +16.4 rich 00000 4203 089 +19.6 100 +16.7 rich 00000 4187 059 +19.6 00 ECU. rich 00000 4498 000 +14.3 00 ECU. rich 00000 4420 000 +7.0 00 ECU. 12.9 00000 3907 000 -0.2 00 ECU. 19.9 00000 3468 000 -7.1 00 ECU. lean 00000 3049 000 -9.1 00 ECU. 24.2 00000 2635 000 -9.1 00 ECU. 24.2 00000 2295 000 -9.1 00 ECU. 24.2 00000 1939 000 -9.1 00 ECU. 24.2 00000 1609 000 -8.9 00 ECU. 24.2 00000 1249 000 -8.7 00 ECU. 24.0 00000 1462 000 -8.3 00 ECU. 24.0 00000 1621 000 -8.5 00 ECU. rich 00000 1535 000 -8.9 00 ECU. rich 00000 1251 000 -9.6 00 ECU. rich 00000 1035 000 -10.4 00 ECU. rich 00000 0793 000 -10.6 00 ECU. rich 00000 0637 000 -10.2 00 ECU. rich 00000 0738 000 -9.1 00 ECU. rich 00000 0814 000 -8.1 00 ECU. rich 00000 0975 000 -7.5 00 ECU. rich 00000 1003 000 -7.5 00 ECU. rich 00000 0944 000 -8.1 00 ECU. rich 00000 0826 000 -8.9 00 ECU. rich 00000 0815 000 -9.4 00 ECU. 12.1 00000 0818 000 -9.6 00 ECU. 12.1 00000 0835 000 -9.4 00 ECU. 12.7 00000 0757 000 -9.1 00 ECU. 13.0 00000 0738 000 -9.1 00 ECU. 13.3 00000 0730 000 -9.1 00 ECU. 13.8 00000 0687 000 -9.1 00 ECU. 14.2 00000 0654 000 -8.9 00 ECU. 14.3 00000 0731 000 -8.7 00 ECU. 14.6 00000 0705 000 -8.5 00 ECU. 15.0 00000 0660 000 -8.3 00 ECU. 15.2 00000 0720 000 -8.1 00 ECU. 15.3 00000 0721 000 -8.1 00 ECU. 15.6 00000 0679 000 -8.1 00 ECU. 15.8 00000 0757 000 -8.1 00 ECU. 16.0 00000 0760 000 -8.3 00 ECU. 15.6 00000 0718 000 -8.3 00 ECU. 15.3 00000 0707 000 -8.3 00 ECU. 15.1 00000 0724 000 -8.3 00 ECU. 15.5 00000 0744 000 -8.3 00 ECU. 15.6 00000 0709 000 -8.3 00 ECU. 15.3 00000 0726 000 -8.3 00 ECU. 15.2 00000 0738 000 -8.5 00 ECU. 15.3 00000 0710 000 -8.5 00 ECU. 15.3 00000 0690 000 -8.5 00 ECU. 15.4 00000 0724 000 -8.5 00 ECU. 15.3 00000 0718 000 -8.5 00 ECU. 15.2 00000 0676 000 -8.3 00 ECU. 15.2 00000 0743 000 -8.3 00 ECU. 15.3 00000 0750 000 -8.3 00 ECU. 15.3 00000 0745 000 -8.3 00 ECU. 15.2 00000 0718 000 -8.5 00 ECU. 14.8 00000 0706 000 -8.5 00 ECU. 14.8 00000 0726 000 -8.5 00 ECU. 14.8 00000 0755 000 -8.5 00 ECU. 15.1 00000 0746 000 -8.5 00 ECU. 15.2 00000 0729 000 -8.5 00 ECU. 15.0 00000 0731 000 -8.5 00 ECU. 15.0 00000 0720 000 -8.5 00 ECU. 15.0 00000 0705 000 -8.5 00 ECU. 15.0 00000 0717 000 -8.5 00 ECU. 14.9 00000 0729 000 -8.7 00 ECU. 15.0 00000 0716 000 -8.5 00 ECU. 15.0 00000 0711 000 -8.5 00 ECU. 15.2 00000 0745 000 -8.5 00 ECU. 15.2 00000 0724 000 -8.5 00 ECU. 15.1 00000 0724 000 -8.5 00 ECU. 15.1 00000 0693 000 -8.7 00 ECU. 15.0 00000 0745 000 -8.7 00 ECU. 14.9 00000 0748 000 -8.7 00 ECU. 14.8 00000 0749 000 -8.7 00 ECU. 14.7 00000 0720 000 -8.7 00 ECU. 14.7 00000 0694 000 -8.7 00 ECU. 14.7 00000 0728 000 -8.7 00 ECU. 14.8 00000 0740 000 -8.7 00 ECU. 14.7 00000 0708 000 -8.7 00 ECU. 14.9 00000 0706 000 -8.7 00 ECU. 15.1 00000 0721 000 -8.7 00 ECU. 15.0 00000 0743 000 -8.5 00 ECU. 15.1 00000 0939 001 -7.5 00 ECU. 15.1 00000 1651 000 -6.9 00 ECU. rich 00000 1742 000 -7.1 00 ECU. 13.6 00000 1743 001 -7.5 00 ECU. 16.4 00000 1673 006 -8.1 00 ECU. 12.9 00000 1717 009 -7.5 00 ECU. 13.3 00000 1702 011 -6.1 00 ECU. 14.5 00000 1748 011 -4.3 00 ECU. 14.6 00000 1773 010 -3.4 00 ECU. 14.8 00000 1926 000 -3.8 00 ECU. 14.4 00000 2213 000 -5.5 00 ECU. rich 00000 2012 000 -7.7 00 ECU. rich 00000 1812 000 -9.8 00 ECU. rich 00000 1863 001 -10.8 00 ECU. 15.4 00000 2256 007 -10.2 00 ECU. rich 00000 2270 012 -8.3 00 ECU. rich 00000 2276 017 -6.1 00 ECU. rich 00000 2298 021 -4.0 00 ECU. 14.4 00000 2354 022 -2.6 00 ECU. 14.3 00000 2331 022 -1.6 00 ECU. 14.4 00000 2406 023 -1.2 00 ECU. 14.6 00000 2415 024 -0.8 00 ECU. 14.7 00000 2465 024 -0.4 00 ECU. 12.1 00000 2510 024 -0.2 00 ECU. rich 00000 2536 024 +0.0 00 ECU. rich 00000 2540 025 +0.4 00 ECU. rich 00000 2583 025 +0.8 00 ECU. rich 00000 2647 024 +1.3 00 ECU. rich 00000 2622 024 +1.7 00 ECU. rich 00000 2723 024 +1.9 00 ECU. rich 00000 2748 024 +2.1 00 ECU. rich 00000 2768 025 +2.5 00 ECU. rich 00000 2815 024 +2.7 00 ECU. rich 00000 2856 024 +2.9 00 ECU. rich 00000 2868 024 +3.5 00 ECU. rich 00000 2939 024 +3.9 00 ECU. rich 00000 2947 024 +4.5 00 ECU. rich 00000 2976 024 +5.1 00 ECU. rich 00000 3046 041 +5.9 00 ECU. rich 00000 3153 077 +7.6 50 +16.0 rich 00000 3177 075 +9.4 70 +15.0 rich 00000 3198 045 +11.9 00 ECU. rich 00000 3211 043 +14.1 00 ECU. rich 00000 3333 043 +15.7 00 ECU. rich 00000 3439 043 +17.0 00 ECU. rich 00000 3501 043 +17.8 00 ECU. rich 00000 3642 043 +18.2 00 ECU. rich 00000 3572 043 +18.4 00 ECU. rich 00000 3667 043 +18.4 00 ECU. rich 00000 3775 043 +18.2 00 ECU. rich 00000 3880 043 +18.2 00 ECU. rich 00000 3949 043 +18.6 00 ECU. rich 00000 4045 043 +19.2 00 ECU. rich 00000 4079 043 +19.2 00 ECU. rich 00000 4203 043 +19.0 00 ECU. rich 00000 4278 062 +18.6 100 +17.0 rich 00000 4363 071 +18.6 100 +17.0 rich 00000 4397 071 +18.8 100 +17.0 rich 00000 4510 071 +19.4 100 +17.0 rich 00000 4642 071 +20.0 100 +18.0 rich 00000 4748 071 +20.0 100 +19.0 rich 00000 4909 070 +19.6 100 +19.5 rich 00000 4952 070 +19.2 100 +20.3 rich 00000 5192 071 +18.8 100 +20.4 rich 00000 5241 090 +18.4 100 +20.7 rich 00000 5291 094 +18.8 100 +21.0 rich 00000 5464 093 +18.6 100 +21.0 rich 00000 5473 094 +19.0 100 +21.0 rich 00000 5678 093 +19.4 100 +21.0 rich 00000 5698 094 +19.2 100 +21.0 rich 00000 5737 093 +19.2 100 +21.0 rich 00000 5827 094 +18.4 100 +21.2 rich 00000 5889 094 +17.8 90 +21.9 rich 00000 6150 093 +17.6 90 +22.0 rich 00000 5963 035 +17.0 00 ECU. rich 00000 5910 000 +10.4 00 ECU. rich 00000 5184 000 +3.9 00 ECU. 16.2 00000 4585 000 -3.6 00 ECU. 24.2 00000 4040 000 -10.0 00 ECU. 24.5 00000 3576 000 -10.4 00 ECU. 24.2 00000 3165 000 -10.4 00 ECU. 24.5 00000 2763 000 -10.2 00 ECU. 24.2 00000 2413 000 -10.0 00 ECU. 24.2 00000 2038 000 -10.0 00 ECU. 24.2 00000 1696 000 -9.8 00 ECU. 24.2 00000 1343 000 -9.6 00 ECU. 24.0 00000 1340 000 -9.1 00 ECU. lean 00000 1499 000 -8.9 00 ECU. 19.7 00000 1356 000 -9.1 00 ECU. rich 00000 1227 000 -9.6 00 ECU. rich 00000 1070 000 -10.2 00 ECU. rich 00000 0878 000 -10.6 00 ECU. rich 00000 0795 000 -10.4 00 ECU. rich 00000 0785 000 -9.6 00 ECU. rich 00000 0944 000 -8.9 00 ECU. rich 00000 0944 000 -8.7 00 ECU. rich 00000 0958 000 -8.7 00 ECU. rich 00000 0924 000 -9.1 00 ECU. rich 00000 0896 000 -9.4 00 ECU. 12.3 00000 0896 000 -9.6 00 ECU. 13.1 00000 0881 000 -9.6 00 ECU. 13.3 00000 0821 000 -9.6 00 ECU. 13.9 00000 0793 000 -9.6 00 ECU. 14.1 00000 0788 000 -9.6 00 ECU. 14.4 00000 0789 000 -9.4 00 ECU. 14.8 00000 0763 000 -9.1 00 ECU. 15.0 00000 0715 000 -9.1 00 ECU. 15.1 00000 0741 000 -8.9 00 ECU. 15.2 00000 0737 000 -9.1 00 ECU. 15.3 00000 0734 000 -9.1 00 ECU. 15.3 00000 0696 000 -8.9 00 ECU. 15.2 00000 0677 000 -8.9 00 ECU. 15.1 00000 0689 000 -8.7 00 ECU. 15.3 00000 0748 000 -8.5 00 ECU. 15.3 00000 0749 000 -8.5 00 ECU. 15.5 00000 0729 000 -8.5 00 ECU. 15.5 00000 0709 000 -8.5 00 ECU. 15.2 00000 0670 000 -8.5 00 ECU. 15.1 00000 0746 000 -8.5 00 ECU. 15.2 00000 0743 000 -8.5 00 ECU. 15.2 00000 0730 000 -8.7 00 ECU. 15.1 00000 0706 000 -8.7 00 ECU. 14.8 00000 0712 000 -8.7 00 ECU. 14.7 00000 1118 022 -7.5 00 ECU. 14.8 00000 1804 000 -6.9 00 ECU. 12.4 00000 1653 000 -7.3 00 ECU. 14.5 00000 1698 002 -7.5 00 ECU. 14.3 00000 1765 003 -8.5 00 ECU. 13.5 00000 2256 003 -8.9 00 ECU. 15.2 00000 2349 002 -8.5 00 ECU. 15.0 00000 2359 003 -8.3 00 ECU. 14.6 00000 2382 009 -7.9 00 ECU. 14.1 00000 2380 010 -7.1 00 ECU. 15.0 00000 2372 011 -5.9 00 ECU. 15.4 00000 2392 012 -4.5 00 ECU. 15.0 00000 2403 013 -3.8 00 ECU. 14.9 00000 2411 015 -3.0 00 ECU. 14.6 00000 2413 017 -2.4 00 ECU. 13.2 00000 2405 020 -2.0 00 ECU. 13.4 00000 2463 020 -1.4 00 ECU. 13.9 00000 2496 021 -1.0 00 ECU. 14.1 00000 2504 021 -0.4 00 ECU. 14.6 00000 2525 038 +0.0 00 ECU. rich 00000 2525 072 +0.6 10 +19.8 rich 00000 2534 094 +1.5 20 +17.0 rich 00000 2590 094 +2.1 20 +17.0 rich 00000 2616 094 +2.9 20 +17.0 rich 00000 2622 094 +3.5 30 +17.0 rich 00000 2692 094 +3.9 30 +17.0 rich 00000 2670 094 +4.5 30 +17.0 rich 00000 2690 094 +4.9 30 +17.0 rich 00000 2743 094 +5.3 40 +17.0 rich 00000 2694 094 +5.9 40 +17.0 rich 00000 2773 094 +6.6 40 +17.0 rich 00000 2829 094 +7.2 40 +17.0 rich 00000 2868 094 +8.0 50 +16.0 rich 00000 2929 094 +8.8 60 +16.0 rich 00000 2883 094 +10.0 60 +16.0 rich 00000 2984 094 +11.5 70 +15.0 rich 00000 2981 094 +13.1 80 +14.0 rich 00000 3041 094 +14.9 90 +14.0 rich 00000 3100 094 +17.0 100 +14.0 rich 00000 3115 094 +18.2 100 +14.0 rich 00000 3189 094 +19.0 100 +14.0 rich 00000 3280 094 +19.6 100 +14.0 rich 00000 3267 093 +19.2 100 +14.0 rich 00000 3320 093 +19.2 100 +14.0 rich 00000 3418 094 +19.8 100 +14.0 rich 00000 3439 094 +19.6 100 +14.0 rich 00000 3370 094 +19.6 100 +14.0 rich 00000 3494 093 +19.4 100 +14.0 rich 00000 3580 094 +19.2 100 +14.0 rich 00000 3531 094 +19.4 100 +14.0 rich 00000 3603 094 +19.6 100 +14.0 rich 00000 3720 093 +20.0 100 +14.0 rich 00000 3736 094 +20.0 100 +14.0 rich 00000 3770 094 +19.8 100 +14.0 rich 00000 3844 092 +19.8 100 +14.4 rich 00000 3880 090 +19.6 100 +14.8 rich 00000 3930 080 +19.4 100 +15.4 rich 00000 3720 000 +17.4 00 ECU. rich 00000 4728 000 +10.8 00 ECU. rich 00000 4374 000 +3.5 00 ECU. 15.2 00000 3849 000 -3.8 00 ECU. lean 00000 3401 000 -9.1 00 ECU. 24.5 00000 2970 000 -10.0 00 ECU. 24.2 00000 2606 000 -9.8 00 ECU. 24.2 00000 2259 000 -9.8 00 ECU. 24.5 00000 1909 000 -9.6 00 ECU. 24.2 00000 1573 000 -9.4 00 ECU. 24.2 00000 1224 000 -9.1 00 ECU. 24.2 00000 1399 000 -8.7 00 ECU. 24.2 00000 1540 000 -8.7 00 ECU. rich 00000 1460 000 -9.1 00 ECU. rich 00000 1277 000 -9.8 00 ECU. rich 00000 1136 000 -10.4 00 ECU. rich 00000 0875 000 -10.8 00 ECU. rich 00000 0669 000 -10.6 00 ECU. rich 00000 0697 000 -10.0 00 ECU. rich 00000 0793 000 -8.9 00 ECU. rich 00000 0843 000 -8.1 00 ECU. rich 00000 0890 000 -7.9 00 ECU. rich 00000 0893 000 -8.1 00 ECU. rich 00000 0844 000 -8.7 00 ECU. rich 00000 0827 000 -9.1 00 ECU. 12.3 00000 0845 000 -9.1 00 ECU. 12.6 00000 0819 000 -9.1 00 ECU. 13.1 00000 0823 000 -9.1 00 ECU. 13.5 00000 0816 000 -9.1 00 ECU. 13.2 00000 0724 000 -9.1 00 ECU. 13.2 00000 0733 000 -9.1 00 ECU. 13.7 00000 0714 000 -9.1 00 ECU. 14.1 00000 0734 000 -8.9 00 ECU. 14.3 00000 0723 000 -8.7 00 ECU. 14.7 00000 0669 000 -8.5 00 ECU. 15.0 00000 0735 000 -8.5 00 ECU. 15.1 00000 0753 000 -8.3 00 ECU. 15.4 00000 0738 000 -8.3 00 ECU. 15.8 00000 0719 000 -8.3 00 ECU. 15.6 00000 0654 000 -8.5 00 ECU. 15.6 00000 0741 000 -8.5 00 ECU. 16.0 00000 0730 000 -8.5 00 ECU. 16.0 00000 0697 000 -8.5 00 ECU. 15.7 00000 0695 000 -8.5 00 ECU. 15.6 00000 0693 000 -8.3 00 ECU. 15.5 00000 0682 000 -8.1 00 ECU. 16.0 00000 0733 000 -8.1 00 ECU. 16.2 00000 0726 000 -8.3 00 ECU. 16.4 00000 0702 000 -8.3 00 ECU. 16.1 00000 0735 000 -8.3 00 ECU. 15.7 00000 0741 000 -8.5 00 ECU. 15.4 00000 0735 000 -8.5 00 ECU. 15.4 00000 0716 000 -8.5 00 ECU. 15.3 00000 0700 000 -8.5 00 ECU. 15.2 00000 0732 000 -8.7 00 ECU. 15.0 00000 0725 000 -8.7 00 ECU. 14.9 00000 0715 000 -8.7 00 ECU. 15.1 00000 0695 000 -8.7 00 ECU. 15.1 00000 0724 000 -8.7 00 ECU. 15.2 00000 0738 000 -8.7 00 ECU. 15.1 00000 0732 000 -8.7 00 ECU. 14.8 00000 0676 000 -8.9 00 ECU. 14.6 00000 0727 000 -8.9 00 ECU. 14.7 00000 0709 000 -8.9 00 ECU. 14.8 00000 0715 000 -8.7 00 ECU. 14.8 00000 0723 000 -8.7 00 ECU. 14.9 00000 0728 000 -8.7 00 ECU. 14.8 00000 0739 000 -8.7 00 ECU. 14.8 00000 0723 000 -8.7 00 ECU. 14.8 00000 0697 000 -8.7 00 ECU. 14.7 00000 0742 000 -8.7 00 ECU. 14.7 00000 0721 000 -8.7 00 ECU. 14.6 00000 0725 000 -8.7 00 ECU. 14.7 00000 0718 000 -8.7 00 ECU. 14.6 00000 0718 000 -8.7 00 ECU. 14.7 00000 0755 000 -8.7 00 ECU. 14.5 00000 0726 000 -8.7 00 ECU. 14.5 00000 0722 000 -8.9 00 ECU. 14.7 00000 0719 000 -8.7 00 ECU. 14.8 00000 0706 000 -8.7 00 ECU. 14.9 00000 0748 000 -8.7 00 ECU. 14.9 00000 0744 000 -8.7 00 ECU. 14.7 00000 0731 000 -8.7 00 ECU. 14.7 00000 0738 000 -8.7 00 ECU. 14.7 00000 0732 000 -8.7 00 ECU. 14.7 00000 0755 000 -8.7 00 ECU. 14.7 00000 0768 000 -8.5 00 ECU. 14.6 00000 0773 000 -8.5 00 ECU. 14.7 00000 0804 000 -8.7 00 ECU. 14.7 00000 0789 000 -8.7 00 ECU. 14.3 00000 0775 000 -8.7 00 ECU. 14.5 00000 0758 000 -8.7 00 ECU. 14.7 00000 0766 000 -8.9 00 ECU. 14.6 00000 0760 000 -8.9 00 ECU. 14.7 00000 0746 000 -8.9 00 ECU. 14.7 00000 0720 000 -8.9 00 ECU. 14.7 00000 0749 000 -9.1 00 ECU. 14.6 00000 0700 000 -9.1 00 ECU. 14.8 00000 0743 000 -8.9 00 ECU. 14.8 00000 0775 000 -8.9 00 ECU. 14.9 00000 0756 000 -8.9 00 ECU. 14.9 00000 0803 000 -8.7 00 ECU. 14.9 00000 0873 000 -8.7 00 ECU. 15.0 00000 0946 000 -8.9 00 ECU. 14.9 00000 0897 000 -9.1 00 ECU. 14.7 00000 0808 000 -9.1 00 ECU. 15.0 00000 0788 000 -9.1 00 ECU. 15.6 00000 0830 000 -8.9 00 ECU. 15.6 00000 0766 000 -8.1 00 ECU. rich 00000 0848 000 -7.3 00 ECU. 14.4 00000 0861 000 -6.7 00 ECU. 13.4 00000 0895 000 -6.1 00 ECU. 13.6 00000 0963 000 -6.1 00 ECU. 14.4 00000 0957 000 -6.1 00 ECU. 15.1 00000 0915 000 -6.3 00 ECU. 16.8 00000 0990 000 -6.5 00 ECU. 17.8 00000 0961 000 -6.5 00 ECU. 16.8 00000 1014 000 -6.7 00 ECU. 16.4 00000 1045 000 -6.9 00 ECU. 16.0 00000 1063 000 -7.1 00 ECU. 15.4 00000 1092 000 -7.3 00 ECU. 15.1 00000 1110 000 -7.5 00 ECU. 14.8 00000 1074 000 -7.7 00 ECU. 14.5 00000 1163 000 -7.9 00 ECU. 14.1 00000 1112 000 -8.1 00 ECU. 13.8 00000 1187 000 -8.3 00 ECU. 13.7 00000 1185 000 -8.5 00 ECU. 13.6 00000 1202 000 -8.5 00 ECU. 13.7 00000 1211 000 -8.7 00 ECU. 13.9 00000 1232 000 -8.9 00 ECU. 14.2 00000 1224 000 -8.9 00 ECU. 14.2 00000 1219 000 -9.1 00 ECU. 14.3 00000 1225 000 -9.1 00 ECU. 14.4 00000 1274 000 -9.1 00 ECU. 14.5 00000 1225 000 -9.1 00 ECU. 14.3 00000 1256 000 -9.1 00 ECU. 14.4 00000 1299 000 -9.1 00 ECU. 14.3 00000 1259 000 -9.4 00 ECU. 14.5 00000 1286 000 -9.4 00 ECU. 14.6 00000 1315 000 -9.6 00 ECU. 14.6 00000 1320 000 -9.6 00 ECU. 14.4 00000 1317 000 -9.6 00 ECU. 14.4 00000 1357 000 -9.4 00 ECU. 14.6 00000 1389 000 -9.4 00 ECU. 14.3 00000 1428 000 -9.1 00 ECU. 14.3 00000 1411 000 -9.1 00 ECU. 14.2 00000 1448 000 -9.1 00 ECU. 14.3 00000 1482 000 -9.1 00 ECU. 14.5 00000 1500 000 -9.4 00 ECU. 14.4 00000 1524 000 -9.4 00 ECU. 14.5 00000 1519 000 -9.6 00 ECU. 14.5 00000 1562 000 -9.6 00 ECU. 14.5 00000 1588 000 -9.8 00 ECU. 14.6 00000 1597 000 -9.8 00 ECU. 14.7 00000 1589 000 -9.8 00 ECU. 14.7 00000 1612 000 -10.0 00 ECU. 14.7 00000 1635 000 -10.0 00 ECU. 14.6 00000 1650 000 -10.2 00 ECU. 14.5 00000 1656 000 -10.2 00 ECU. 14.5 00000 1678 000 -10.2 00 ECU. 14.4 00000 1674 000 -10.4 00 ECU. 14.4 00000 1705 000 -10.4 00 ECU. 14.4 00000 1704 000 -10.4 00 ECU. 14.4 00000 1711 000 -10.4 00 ECU. 14.2 00000 1712 000 -10.6 00 ECU. 14.2 00000 1717 000 -10.6 00 ECU. 14.4 00000 1737 000 -10.6 00 ECU. 14.3 00000 1749 000 -10.6 00 ECU. 14.3 00000 1734 000 -10.6 00 ECU. 14.4 00000 1753 000 -10.4 00 ECU. 14.5 00000 1768 000 -10.6 00 ECU. 14.5 00000 1758 000 -10.6 00 ECU. 14.6 00000 1763 000 -10.6 00 ECU. 14.6 00000 1775 000 -10.6 00 ECU. 14.5 00000 1781 000 -10.6 00 ECU. 14.6 00000 1769 000 -10.6 00 ECU. 14.6 00000 1781 000 -10.6 00 ECU. 14.4 00000 1788 000 -10.8 00 ECU. 14.5 00000 1789 000 -10.8 00 ECU. 14.5 00000 1783 000 -10.6 00 ECU. 14.6 00000 1799 000 -10.6 00 ECU. 14.7 00000 1790 000 -10.6 00 ECU. 14.7 00000 1784 000 -10.4 00 ECU. 14.6 00000 1789 000 -10.4 00 ECU. 14.6 00000 1789 000 -10.4 00 ECU. 14.7 00000 1787 000 -10.4 00 ECU. 14.7 00000 1803 000 -10.4 00 ECU. 14.5 00000 1791 000 -10.4 00 ECU. 14.5 00000 1795 000 -10.6 00 ECU. 14.6 00000 1803 000 -10.6 00 ECU. 14.6 00000 1818 000 -10.4 00 ECU. 14.7 00000 1814 000 -10.6 00 ECU. 14.4 00000 1812 000 -10.4 00 ECU. 14.4 00000 [1;24r[0m[2J[01;05H[0m[4mHOME MENU[0m[01;44H[0m[4mTURBOXS UTEC (Version 4.2c) (c) 2004[0m[03;05H Key : Function[04;05H------------------------------------------------------------[05;05He or E : Edit Maps (Caps lock must be OFF)[06;05H[07;05Hd or D : Dashboard[08;05H[09;05Hl or L : Logger[10;05H[11;05H1 to 6 : Data Logger (<Shift - 1 to 6> : for .csv format)[12;05H[13;05Hr or R : Replay Last 25 Seconds of Data (Logger 1)[14;05H i hope this will help a bit...
Oh i see what happended! if you look at the 249th line down then go over 8 digits, that code is for low blinker fluid, and lack of fluxxing from the flux capacitor! JK I just wanted to seem smart! Tim
It also looks like you are pretty rich down low (onset of boost), but you will need to post up logger 1 so I have some good info to look at. Russ
If you drive a WRX with the stock TD04 turbo with a turbo back exhaust with the wastegate flutter fix, maybe the reflash was designed to keep the stock wastegate arm setting/length. My $.02.
well, my 10% load site starts at a tps value of 20. i see you are letting the ecu handle thigs till 60. this would make cruising kind of smooth, but when you are really getting on top of things you would feel the crossover. i'd do some wb 02 logging and use the logger #1. i dono on a wrx, where your transition should be, but imo it's better to get it out of the way down low. then again, i'm a noob so disreguard most of what i said.
yeah but looking at the log, hes making boost. bad coils will cause cutout while still invaccume.... imo
Aaron is right. I had a dead coilpack too, you can't make crap for boost and it misfires like crazy if that's the problem, so this guy has something different going on.
