It's a toss up!
Discussion in 'Off-Topic' started by Substeroo, Feb 20, 2005.
  1. Substeroo
    Substeroo Well-Known Member
    between these two tires.
    Yokohama ES100 $98
    Avon Tech M500 $104
    Both have:
    Treadwear: 280
    Traction: AA
    Temperature: A
    Speed Rating: WR
    They will be size 245/45/16
    Any suggestions or experiences?
  2. Musashi
    Female
    Clouds
    My suggestion would be:
    Option A
    Kumho Ecsta Supra 712 $98 shipped
    245/45ZR-16 94W B
    Specifications:
    Treadwear: 280
    Traction: A
    Temperature: A
    Speed Rating: ZR
    Kumho has derived the new ultra-high performance Supra 712 from their track-inspired, race winning technology. Featuring the latest in tread compound development and tread design innovation, this tire will make your car handle like it's "on rails."
    •Advanced directional tread design delivers superior acceleration, braking and cornering grip.
    •New silica tread compounding provides excellent traction in all road conditions while it enhances wear.
    •Two wide steel belts and nylon cap plies deliver high-speed stability, excellent cornering power and stable footprint for better wear.
    •Large lateral center channels provide effective water evacuation and hydroplaning resistance.
    •Available in a wide range of sizes from 15" to 18" and profiles between 35 and 55 series.
    Option B
    Falken GR Beta FK-451
    245/45ZR-16 94Y B
    Specifications:
    Treadwear: 280
    Traction: A
    Temperature: A
    Speed Rating: ZR
    Exotic looks, style and performance are keys to the new GRB FK-451. Deep lateral grooves and directional tread deliver great curb appeal as well as excellent wet traction. A new tread compound steps up to deliver the dry traction you want. Integrated sidewall ridge protects your rim investment. Available in ultra low profiles at surprisingly affordable prices.
    •Two wide center grooves enhance wet traction and minimize noise.
    •Wide steel belts and jointless nylon caps protect the tread, stabilize the tire at speed and deliver long wear.
    •Sidewall is stiffened by high ply turn up and stiff apex bead rubber for better cornering control at speed.
    •Special silica compound delivers excellent wet and dry handling.
    •Z speed rating. Available in ultra low profiles.
  3. hercules
    hercules New Member
    TC
    nice tip option A was actually gonna be my spring/summer tires...
  4. kickin_81
    kickin_81 Well-Known Member
    St. Paul
    My next set of tires would be the Yokohama ES100's again. They are quiet handling tires that lasted me about 30,000 miles and didn't squirm when I tested their potential from time to time. Go to Tirerack and read the reviews on the tires. Based on those reviews, the Kuhmo Ecsta 712 tires were the worst. Go figure...? :)
  5. Zola
    Zola Well-Known Member
    St Louis Park
    I don't know a single person who has owned a set of Ecsta Supras and bought them a second time.
  6. Substeroo
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by kickin_81
    This is good to know. Any more comments?
  7. Substeroo
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by Substeroo
    Yokohama ES100 $98
    Avon Tech M500 $104
    Both have:
    Treadwear: 280
    Traction: AA
    Temperature: A
    Speed Rating: WR
    http://www.tirerack.com/tires/tires...=25WR6EMX&index=2&vIndex=3&vehicleSearch=true
    http://www.tirerack.com/tires/tires...5WR6ES100&index=3&vIndex=3&vehicleSearch=true
  8. Dynapar
    Orono, MN
    i have potenza g009's and they are AWSOME! atleast fro all seasons.
  9. Substeroo
    I am going to be hitting the track with these tires as well as using them for daily use so, I want something more than all seasons. Thanks though!
  10. Gspot
    Gspot New Member
    If they make Kumho Ecsta MXs in that size I would recommend those.
  11. Dynapar
    Orono, MN
    you see the new michelin airless tires? crazy stuff.
  12. kickin_81
    St. Paul
    Let me add to this discussion that the ES100 tires, being the hard compound summer tire they are, follow grooves on the road. You'll be fighting to keep the car going straight on a bad freeway/street. This groove following slowly goes away as you put more miles on the tires though. I'm uncertain how other summer tires react to this "groove following" either, but take it into consideration on your next set of wheels if you plan to do mostly city driving.
  13. Grimm
    Grimm New Member
    I got those Yokohama AVS db S2's, and I am happy with them. I got all seasons because I am lazy and I will probably get new rims for track tires :p. But even rated as crapy as they are for winter I have only had 2 days where they were a little too slippery. All in all I am happy with them. Good grip / hydroplan resistance. Maybe once i build up a little stash affter the cryo brakes, and tires for the NSX I will have some money to get tires/rims for the track.
  14. Substeroo
    Thanks I think I'm going to go with the yokos.
