JDM emblem install.
Discussion in 'Modifications And Maintenance' started by blackozone, Nov 22, 2007.
  1. blackozone
    Mods, get ready to make this one a sticky.
    Things you'll need:
    1) A flathead screwdriver
    2) A heatgun/blowdryer
    3) Mad TytE JDm Emblems for extra whp.
    OK, so first thing you do is jam your screwdriver under the existing grill emblem. Once you've accomplished that, pry it out. Stick your new emblem in its place and you're done.
    For the 06 trunk emblem, these are bolted on through the trunk. The best thing you can do is either modify them by sanding down the backs and re-painting them the color you want, or buying some specifically for the trunk. Which probably won't happen, so you'll have to sand them. Since I have an 02, I'm not doing a writeup for you pig-nosed bastards :p
    Now you're done, feel free to show off your new pink JDM hotness yo, the bitches'll be all over you.
    NOTE: The emblems are not an overlay and are made to be replacements. For the love of God/Allah/Jesus/Buddah/Zeus/Xenu , don't do this:
  2. phi11
    yes, always clean off the tar remover with rubbing alcohol, before new emblem goes on.
  3. Bullwinkle
    I'm fairly sure that the '06+ Subaru emblem is bolted on through the trunk, not just held on with adhesive like the other Subaru text.
  4. Paul Revere
    Is it just me or does it look like he put the new one on over the old one??
  5. curly2k3
    he did
  6. blackozone
    Bullwinkle's right, they're bolted. Leaves holes.
  7. tux121
    tux121 Well-Known Member
    hahahahahaha yes im famous. not in a good way but i stil am!
  8. 1_sic_rex
    1_sic_rex Well-Known Member
    ^^^^fail!
  9. CGM2007WRX
    CGM2007WRX Well-Known Member
    there not bolted they are just stuck on with two studs that stick in the holes in the trunk. see in pick i took mine off and repainted it.
  10. tux121
    yeah they are not bolt. But I can't find one with the same size as the stock one. I wanted that big chrome border. Nice re-painted one by the way. COOL!!
