JDM TAILS For GC8: Bulb question
Discussion in 'Modifications And Maintenance' started by hakstern, Mar 25, 2007.
  1. hakstern
    hakstern Member
    Willmar
    Alright, I installed some Jdm taillights that came from JDM land. One of the bulb is blown. The bulb that is blown is the pasenger side signal bulb. I thought I was able to just take it from my USDM taillights, but found out it won't fit. I looked at the little "nipples" on the bulb and they are different. The JDM ones are not parallel as the USDM one. Does anyone know where I can get some signal bulbs for my JDM taillights? I already searched at the following places: WALMART, NAPA, RADIO SHACK, and a couple of independent stores. I'm located in WILLMAR...so I don't have much of a veriety to choose from. I need the bulb pretty badly as I don't like the ricer/hyper blinker.... Thanks in advance
    -Bryan
  2. John16V
    John16V Well-Known Member
    You can get them at Wal-mart, but look for bulb that are made for European car. Check the nipple location. Hope that help ;)
    I can also check the number for you soon as I get home tonight.
    Good luck.
  3. hakstern
    hakstern Member
    Willmar
    I treid walmart and I couldn't find it..I guess I missed it or something...If you can give me the Number for the bulb I would GREATLY Appreciate it!
  4. stoooo
    stoooo Well-Known Member
    North Yorkshire, UK
  5. John16V
    Got it!
    It should be 1157, but double check and make sure the nipples is at the 4 and 8 o'clock mark.
    Good luck
  6. s7udmuffin
    s7udmuffin New Member
    Hakstern: Thanks alot bro! I'll check on it tomorrow!! Then after I can finish putting on the rubber seal ;-) I'll post some pix later once I'm finished.
