These are the last remaining parts worth anything from my part out. JDM WRX RA Transmission, it did have a welded center dif, but I removed the welded dif for another one so this transmission is streetable again! When I had it apart everything look to be in good shape and last time it was driven it worked great. 4.11 f/d and I do have a open rear diff or welded rear dif to match, would be easy to swap ring and pinion on to a Vlsd if you have one. $650 OBO Early ej20G. From a legacy. Needs a rebuild. Heads are good. No I do not know what year, whats wrong, how many miles, or if it will work in your car. please do your research. again this engine NEEDS a rebuild. Comes with stock good turbo $150 firm on this one. Grimspeed AOS I've had this up for sale for awhile and really surprised it has not sold. $125 Ebay TMIC with stock BPV. $60 obo 850cc sidefeed injectors. used for e85 $100 OBO Please give me a call or text and leave me a message. 764 443 9064. All parts are located in coon rapids. can meet in fridley also. Ryan
Not ar the moment no. I can assure it.. it looks exactly like it should and will still need a rebuild. Everything is there for it. You can certainly come look at it if youd like
want to see if there is a bolt there for the newer since i need the heads maybe but if they cant take coil packs then yea cant use em
Still have a ton of stuff. Best offer on everything. Don't be afraid to offer, I'm getting out of subaru's completely and just want this stuff gone!!
