just my luck...
Discussion in 'General Subaru Discussion' started by thomas manship, Oct 6, 2014.
  1. thomas manship
    thomas manship Member
    so just my luck after over 1000 $ for a motor rebuild and after a new radiator after it exploded literally all over me, my new radiator went out... Again. Just saying I suppose be weary about going with cheap radiators for a very hot blooded car.
  2. toyotanos
    toyotanos Well-Known Member
    Coon Rapids, MN
    What radiator cap were you running? I've seen a couple problems when using high-pressure caps, but that's on Toyota- not Subaru.
  3. thomas manship
    yeah using a stock radiator cap... but i was talkin to a few of the techs at bloomington subaru and they pointed me in the same direction.
  4. JavaBlack-Beast
    JavaBlack-Beast Member
    SaintPaul.minnesota
    mine blew and i bought a mishimoto right away you can get one on amazon for pretty cheap
  5. jas3087
    jas3087 Well-Known Member
    Champlin
    I personally would question the authenticity of the Mishimoto from Amazon...
    Ryan FailRad likes this.
  6. JavaBlack-Beast
    SaintPaul.minnesota
  7. DoughtCom
    DoughtCom Well-Known Member
    Plymouth
    I have a brand new mishimoto on my Subaru right now, I ordered it off of Amazon last week using the URL JavaBlack-Beast posted. With this said, I've had two radiators from these guys... both the caps exploded off. I went to O'Reilly and got an OEM type cap from there and it's been fine.
  8. project/driven
    coon rapids
    The mishimoto caps are crap. Just use OEM caps and that radiator will work fine.
  9. toyotanos
    Coon Rapids, MN
    When it comes to Rad caps and T-stats I only go OEM from the dealer. Too much rides on their operation to risk my engine over $25.
    Sjogun likes this.
  10. Sjogun
    Sjogun Active Member
    Bloomington
    Agree oem cap for sure, I've seen many aftermarket caps fail and push coolant out of the overflow tank.
    thomas manship likes this.
  11. thomas manship
    radiator cap failure.... Pressure tested the thing and failed.
    EricS likes this.
