Just ordered a V1
Discussion in 'Modifications And Maintenance' started by capone, Sep 11, 2004.
  1. capone
    Online
    capone Guest
    I am pumped about the V1. :D Next is Lidatek. Anyone have any good custom installs of the V1?
  2. yosmiley
    Will, there's a few guys in here who uses radar detector. You may want to check with bikerboy or wrx1 and a few others.
  3. Yang
    Yang Well-Known Member
    I think John had a V1; he later got rid of it cause he got a ticket i think
  4. MNAutomatic
    MNAutomatic New Member
    I got a V1 thats hardwire into my system with the secrete display atop my steering column. Looks real nice. Let me know if you wants pics or any help. Takes literally 20 minutes top depending on if you want it switched or unswitched
  5. DISCOPOPE
    DISCOPOPE Well-Known Member
    ive seen the slick install off of the dome light.
    it looks pretty clean.
  6. John16V
    John16V Well-Known Member
    Capone,
    I wish you the best of luck with the V1....but don't rely on it too much....check my older post...most cops use laser now, and when they zip you is allllll over....
  7. BlackDubRX
    BlackDubRX New Member
    Does the V1 only detect K-band or something?
  8. Zola
    Zola Well-Known Member
    It detects laser I think, but if you are speeding, by the time it detects laser they already have you by the balls. I don't think you can rely on any one detector...you have to use some common sense too.
  9. DISCOPOPE
    v1 detects everthing but pop.
    v1 is a very nice unit, but even a very nice unit will get you a ticket if the cops are using laser.
    i went from the bel 975r to the belpro rx75 with the bel add on 905 laser defense system.
    so far i've been deadon directly tagged in a laser trap once, coming into downtown on 394.... and made it through... as i passed, the cop was looking at the gun and had a slightly puzzled look.
    laser traps,you will find, will only be out on overcast days. sunlight is bad..
    there is a film, that you can get to block your lamps, your plate, and i think your nose.. kind of like a rockblocker but made to reflect close to zero % laser.
  10. MNAutomatic
    you can do that but good luck getting it shipped to MN unless it is through a second hand dealer. Any sort of laser diffuser or stopper is now illegal in MN so it is tough to get your hands on them unless you buy them through ebay
  11. capone
    Online
    capone Guest
    lidatek will ship to MN.
  12. DISCOPOPE
    i can buy bel at wholesale, not belprol.
    the laser defense add on is standard bel.
    i had to get the rx75 at retail.
    the laser sales laws are a little lax in mn.
    and the units that block look identical to the newer style laser sensors... no way to really tell visably.
    i believe ultimate electronics sells the full escort system..
  13. BlackDubRX
    !!! escorts have laser jammers built in??????
    I'm off to UE right now!
  14. John16V
    me too.....
  15. DISCOPOPE
    not built in really, you buy the add on defense system that has an extra box, 3 blockers, and a cable to connect with some of their detectors which have the ability to communicate and control the blocker..
    in bel dash mount units you go with either the 965 or the 995 then add on the lp-905. i do not know the corrosponding escort model #'s
  16. capone
    Online
    capone Guest
    the escort with jammers is like $1200 IIRC
  17. DISCOPOPE
    for the stealth set up yes.
    but i believe some of their <$200 dash units have the blocker control codes.
    i'll look.
    fwiw the beltronics full stealth system with blocking will cost you about $800
  18. DISCOPOPE
    ok i was diluted, passport/escort do not seem to offer the blocker outside of the stealth system....
  19. igofast
    igofast New Member
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by DISCOPOPE
    I don't think you were. I remember when I bought my 8500 a couple years back I bought the jammer system with it, it was only ~$300 at the time. I ended up taking it back after seeing what a pain it was to mount, which I regret. It's a bummer if they don't offer it anymore seperately.
  20. capone
    Online
    capone Guest
    Also, mine does have protection against pop. In the box it had a sheet talking about how this is the most updated version. It stated that it had POP and all those who want to know if they do. Turn it on and it should say "P" "o" "P" (In the display) after all the alerts go off.
  21. DISCOPOPE
    yes, it is a bit disconcerting to pass by the speed trap with out a chirp......
    pop has the potential to be a bigger problem than ladar if they can get it to function correctly...
