K&N filter?
Discussion in 'Modifications And Maintenance' started by Xcelor8, Mar 1, 2006.
  1. Xcelor8
    Xcelor8 Well-Known Member
    Noob question :D
    Can I safely put a K&N filter in my car, I'm 100% stock right now.
  2. Dream
    Yes
  3. Sogonerg
    Sogonerg Anteater
    ^Agree...You will hear better air flow for your car, but you won't feel any gain
  4. Xcelor8
    Thanks, not concerned about 1hp, I'd just rather buy a filter and be done with it, I run them in everything else I own.
    So K&N then, or is there another brand I should buy, for any other reason, like say you guys know of another cleanable filter that's cheaper, or whatever, don't have to be a K&N, probably splitting hairs now. :lol:
  5. Sogonerg
    Sogonerg Anteater
  6. wall of tvs
    Stock, or a WIX filter. Both flow just fine and trap MUCH more dirt than a K&N.
    IMHO, better, cleaner filtration > .0004 cfm higher flow.
  7. Xcelor8
    BTW I ended up buying a wix filter, man what a difference it makes!, I'm actually ashamed to admit the air filter in there was probablyt the original, with some 40K miles on it. :eek: It's stupid how dirty the filter was.
  8. SubaruPartsGirl
    Online
    SubaruPartsGirl Guest
    Either way, a clean air filter is essential. One benefit of the K&N is that it never needs replacing, you only clean it. This saves quite a bit of money over time but if you don't want to bother with the cleaning process then the plain ones are just as sufficient.
    Jackie
  9. Dream
    How about an introduction?
  10. TSTRBOY2004
    down tiger.. woohoo another girl on the forum...
  11. DISCOPOPE
    DISCOPOPE Well-Known Member
    oh man...
    ibtehleghumppingstarts.
  12. TSTRBOY2004
    not me baby... sperms to strong form the man from down under.. 3 kids in under 3 yrs.. gotta watch what I walk next to yet alone hump.. ha ha ha
  13. scoobydreamin
    scoobydreamin Well-Known Member
    There ya go guys, nice welcome....
  14. AspitFire
    lol, potent stuff it can be
  15. Cannonball2
    Cannonball2 New Member
    K&N is fine, may not fit the best on some cars. Just use caution when you go to clean the unit. These units don't like to be doped with excessive lube/solution. It can lead to CELs and such due to the mass airflow sensor probes getting coated. (Non Chlor. brake cleaner does the trick)
    Try the Purolator replacement - it has a solid frame and tight fit. Gotta keep them tight.
