If you go Kartboy, use the discount code "facebook" and the end links come out to like $180 shipped. If you actually have a facebook, Leo from MAP says he can get a better price than buying direct from Kartboy, so that'll be worth checking into as well.
PS, here's my random tidbit of info for the day. I recently learned the benefits (and how to properly install ) of adjustable endlinks - like the whiteline adjustable endlinks. They allow you to dial-out sway bar preload. If you're lowered and using stock endlinks, it's very possible that there is preload on the sway bar if it had stock length endlinks. Preload will negatively affect the function of the sway bar and car handling. It is actually really easy to adjust the whiteline endlinks to dial out the preload. I used to not understand how to adjust them or the purpose, but I took a few minutes to research, and now it makes complete sense. Long story short, you may want to consider adjustable endlinks. /end random info dump
Thanks for the helpful info, but it's going on a stock car. nothing too special, just that one of them is broken.
Sure thing. My apologies, I don't have personal experience using MAP - just wanted to throw out another option.
I've got a set of stock 07 STi endlinks that you can have, if that tickles your fancy. As long yours is a sedan, I think they are the same.
Don't you live kinda far from the cities? LOL Anyways, thanks, i'll probably just end up buying aftermarket ones, which is what i wanted to replace them with.
