Kenwood DDX616 with Navigation and Bluetooth $300.00
Discussion in 'For Sale : Car Parts' started by MNGman, Aug 19, 2014.
  1. MNGman
    MNGman Well-Known Member
    Selling my Kenwood DDX616 head unit with the optional Navigation Module.
    This is in perfect working order, already wired for Subaru and will include the Ipod/Iphone adapter (not for the 5 models) and a USB port expander. I used this to run the Iphone adapter and another usb extension cable for a flash drive since the unit only has 1 usb port. I never had any issues with this configuration. \
    The start up screen and background screen are completely customizable, along with the colors of the controls. I have updated all the firmware, except the maps. The unit is ready for new maps, I just didn't bother with the purchase.
    The GPS is a separate module. I had this mounted in my glove box. System does have bluetooth, but will not stream music via the bluetooth. I was able to stream pandora through the Iphone interface by starting the app manually on the phone. It won't start using the head unit interface.
    I will happily answer any questions. Unit is pulled and ready to go. Here's a crappy video. I really should have thought about this before I pulled it out...
  2. Vinnie
    Vinnie Well-Known Member
    You you need anything special to run Sirius radio? Special receiver or anything?
  3. MNGman
    I think you will need a sperate module for that. The link in my description will take you to Crutchfield, that should tell you.
  4. Curry
    Curry Well-Known Member
  5. ImprezaWrx9
    ImprezaWrx9 Well-Known Member
  6. MNGman
    Thanks, but I don't have a need.
  7. MNGman
    Putting this back on the front page, make an offer.
  8. joebush44
    joebush44 Well-Known Member
    This is a bit off topic, but how did you get the Subaru start up screen? Is there simply an option built in for you to customize it? I have a Kenwood Excelon DDX790 and I don't believe it has this feature built in...good luck with the sale!
  9. Curry
    Most Head Units allow you to change the start up screen and/or background wallpaper. You should be able to upload your own picture via usb/memory card
    @MNGman, what did you get to replace this?
  10. joebush44
    From my limited research, I found that it requires a special gama tool that only Kenwood dealers have access to use...here: http://www.kenwoodforums.com/viewtopic.php?f=12&t=3734
    I was just curious if he had a built in option on his or if there was some other fancy way it was updated. Don't mean to thread jack. Someone will scoop this up - very nice unit.
  11. MNGman
    No special tool needed. I found a .jpg image and used that. You load that onto a blank USB device and during start up press a couple of buttons and then the new screen is in use. It is a very easy process. I can't say if this is an option for the DDX790.
    Lots of YouTube videos for adjusting, and changing boot and background screens.
    joebush44 likes this.
  12. Dus10
    Dus10 Member
    take 250?
  13. MNGman
    Still for sale, will take $250.00
    Couple of tire kickers, no takers.
  14. MNGman
    Sold!
    This can be locked up.
