Keyless entry remote (fob) for 2005 saabaru
Discussion in 'Want To Buy : Cars/Parts' started by Impreziv, Nov 25, 2010.
  1. Impreziv
    Impreziv Well-Known Member
    Just like the title says, I am looking for a key fob in decent shape that is working. Also if you know how to program it that would rock, if not I know I saw a DIY on programming remotes somewhere recently.
  2. olegrad
    olegrad Well-Known Member
    I have one from an 05 sti. Not sure if it works but pm me if interested.
  3. JasonoJordan
    I have one for a 02 wrx not sure if that will work or not
  4. Impreziv
    Thanks olegrad, worked great!
  5. Brewski_143
    Brewski_143 Well-Known Member
    Were you able to get it programmed? If you need, I can get you the programming procedure for an 05 Subaru. I am a Subaru tech. Also a random FYI for you... Subaru recently updated all key fobs ever made to 1 part number. Programming procedure stays the same for each model as it was before. It would be the same fob used for the newest Foresters and Imprezas. It excludes models in which the key and fob is one piece like newer legacys and outbacks.
  6. Impreziv
    Hey thanks, i figured the programming out just fine. Took a few tried until I read some directions that said not to open the door before the 10 cycles and then it worked first try. Its the Tear drop shaped 05 STi key fob and works great.
