King XPG 52mm Rod Bearings - std/stdx mix - NIB
Discussion in 'For Sale : Car Parts' started by istoptofly, Feb 22, 2013.
  1. istoptofly
    istoptofly Well-Known Member
    St Paul
    I used half of each to get the oil clearances I was after, so half of each are for sale. New never run, only some light marks on the standard halves from measuring (no marks on the X halves).
    If you know you need this setup, it saves you from buying 2 sets!
    Part numbers -
    CR4125XPG STD
    CR4125XPG STDX (.001 extra clearance)
    $45 for the mixed set.
