Knock sensor
Discussion in 'General Subaru Discussion' started by prezawagon, Jul 19, 2005.
  1. prezawagon
    prezawagon Well-Known Member
    Anyone know how to test a knock sensor? My car has a P0325 DTC. I pulled the knock sensor off and tested it with my multimeter, and I'm getting zero continuity through it (infinite resistance). Just wondering what it's supposed to be at. I would expect there is an acceptable resistance range for the sensor?
    I seem to remember reading a while ago about trouble with impreza knock sensors, and that is usually wasn't the sensor itself. Anyone have any experience with this?
    Thanks,
    Joel
  2. RichWRX
    RichWRX Well-Known Member
    My whife had the same code on her Rs, they changed the knock sensor and thew code cleared
  3. prezawagon
    Ok, thanks. So I guess the sensor itself can go bad.
    Anyway, I couldn't do anything about it tonight so I just cleaned all the corrosion off of the parts and retourqed it to 17 ft lbs. We'll see if the code comes back on the way to work tomorrow.
  4. TSTRBOY2004
    just sent ya an email with a doc attached for a diagnostic procedure for checking that code...
