List of codes to disable for air pump delete?
Discussion in 'Modifications And Maintenance' started by Kosh, May 14, 2014.
  1. Kosh
    Kosh Well-Known Member
    Is this the right list of DTC's to disable in AccessTuner Race? I have a 2008 STi undergoing the procedure due to the P2440 coming on. I figure I might as well solve the problem.
    P0410 Secondary Air Injection System <Ref. to GD(H4DOTC)-98, DTC P0410 SECONDARY AIR INJECTION
    SYSTEM,Diagnostic Trouble Code (DTC) Detecting Criteria.>
    P0411 Secondary Air Injection System Incorrect Flow Detected
    <Ref. to GD(H4DOTC)-107, DTC P0411 SECONDARY AIR INJECTION
    SYSTEM INCORRECT FLOW DETECTED, Diagnostic Trouble Code (DTC)
    P0413 Secondary Air Injection System Switching Valve “A” Circuit Open
    <Ref. to GD(H4DOTC)-108, DTC P0413 SECONDARY AIR INJECTION
    SYSTEM SWITCHING VALVE “A” CIRCUIT OPEN, Diagnostic Trouble Code
    P0414 Secondary Air Injection System Switching Valve “A” Circuit Shorted
    <Ref. to GD(H4DOTC)-109, DTC P0414 SECONDARY AIR INJECTION
    SYSTEM SWITCHING VALVE “A” CIRCUIT SHORTED, Diagnostic Trouble
    P0416 Secondary Air Injection System Switching Valve “B“ Circuit Open
    <Ref. to GD(H4DOTC)-109, DTC P0416 SECONDARY AIR INJECTION
    SYSTEM SWITCHING VALVE “B” CIRCUIT OPEN, Diagnostic Trouble Code
    P0417 Secondary Air Injection System Switching Valve “B“ Circuit Shorted
    <Ref. to GD(H4DOTC)-109, DTC P0417 SECONDARY AIR INJECTION
    SYSTEM SWITCHING VALVE “B” CIRCUIT SHORTED, Diagnostic Trouble
    P0418 Secondary Air Injection System Control “A” Circuit Open<Ref. to GD(H4DOTC)-110, DTC P0418 SECONDARY AIR INJECTION
    SYSTEM CONTROL “A” CIRCUIT OPEN, Diagnostic Trouble Code (DTC)
    P2431 Secondary Air Injection System Air Flow /Pressure Sensor Circuit
    Range/Performance<Ref. to EN(H4DOTC)(diag)-345, DTC P2431 SECONDARY AIR INJECTION
    SYSTEM AIR FLOW /PRESSURE SENSOR CIRCUIT RANGE/PERFORMANCE,
    Diagnostic Procedure with Diagnostic Trouble Code (DTC).>
    P2432 Secondary Air Injection System Air Flow /Pressure Sensor Circuit Low
    <Ref. to EN(H4DOTC)(diag)-348, DTC P2432 SECONDARY AIR INJECTION
    SYSTEM AIR FLOW /PRESSURE SENSOR CIRCUIT LOW, Diagnostic
    P2433 Secondary Air Injection System Air Flow /Pressure Sensor Circuit High
    <Ref. to EN(H4DOTC)(diag)-351, DTC P2433 SECONDARY AIR INJECTION
    SYSTEM AIR FLOW /PRESSURE SENSOR CIRCUIT HIGH, Diagnostic
    P2440 Secondary Air Injection System Switching Valve Stuck Open
    (Bank1)<Ref. to EN(H4DOTC)(diag)-354, DTC P2440 SECONDARY AIR INJECTION
    SYSTEM SWITCHING VALVE STUCK OPEN (BANK1), Diagnostic
    P2441 Secondary Air Injection System Switching Valve Stuck Closed
    (Bank 1)<Ref. to EN(H4DOTC)(diag)-358, DTC P2441 SECONDARY AIR INJECTION
    SYSTEM SWITCHING VALVE STUCK CLOSED (BANK1), Diagnostic
    P2442 Secondary Air Injection System Switching Valve Stuck Open
    (Bank2)<Ref. to EN(H4DOTC)(diag)-359, DTC P2442 SECONDARY AIR INJECTION
    SYSTEM SWITCHING VALVE STUCK OPEN (BANK2), Diagnostic
    P2443 Secondary Air Injection System Switching Valve Stuck Closed
    (Bank 2)<Ref. to EN(H4DOTC)(diag)-363, DTC P2443 SECONDARY AIR INJECTION
    SYSTEM SWITCHING VALVE STUCK CLOSED (BANK2), Diagnostic
    P2444 Secondary Air Injection System Pump Stuck On
    <Ref. to EN(H4DOTC)(diag)-364, DTC P2444 SECONDARY AIR INJECTION
    SYSTEM PUMP STUCK ON, Diagnostic Procedure with Diagnostic
    b0yjeenyus likes this.
