Look what just arrived!!!
Discussion in 'General Subaru Discussion' started by Scuba Steve, Aug 16, 2007.
  1. Scuba Steve
    Okay, I have to 'one up' my boss Silver03 and his suspension post so here ya go.
    just arrived at the office. new (0 miles) FP16g and ss oil line!!!!!!!!!:yumyum:
  2. mnstilynwrx
    mnstilynwrx Well-Known Member
    OOhhh Boy! that sould be fun. is that in like shrink rap? looks funny to me or is it just in like a plastic bag? when you putting it in?
  3. Scuba Steve
    yeah, shrink wrap. I waiting on some misc parts..then going in asap. SHould be by the 1st of Sept? I hope!~
  4. wall of tvs
    which flavor of 16g may I ask?
  5. project/driven
    You're gonna have alot of fun with that thing.
  6. Scuba Steve
    unscented flavor!:biggrin:
    I jumped on this one because evidentially FP was in the middle of changing things up a bit. their fp evo3 model is now only 550 cfm..dropped from 575cfm whereas this one is 510 cfm.
  7. project/driven
    It's the same thing I'm running, it makes pretty good power, even with my too small, soon to be replaced STi top mount.
  8. Scuba Steve
    what injectors, bcs and tune do you have? also, have to dyno'd the car?
  9. project/driven
    I'm running DW 650 injectors, a Perrin BCS, and a tune from DB. I think the power numbers are a little down due to lack of intercooler flow, but it did put down 220 whp before the clutch took a dump on the dyno at around 16 or so psi. I'm trying to decide what to do about my intercooler set up and then it's going back to the dyno for some more tweaking.
  10. Bielke55
    Sealed for freshness!
    Good luck with your install...
    BTW... dont forget oil (*looks at chet with a smart ass grin*)
  11. Scuba Steve
    Ummm...I dyno'd about the same with Cobb OTS stage 2 at LSE performance last year. Personally could give a rats butt for numbers, but still think I should be around 270-280 with the set-up
  12. Scuba Steve
    install should be easy
  13. project/driven
    That's what I was hoping for but for some reason everything that has been done to my car has delivered dissapointing dyno numbers. The butt dyno on the other hand has allways read big increases. I think I've just got a car that just doesn't wanna make any power numbers. Does anybody think that the sti intercooler as opposed to a big top mount(ssac or the like), or a front mount is where I'm coming up short?
  14. Scuba Steve
    Once I get mine done and tuned properly I'll let you know what I get for numbers. I think you just need some tweaking done. the clutch slipping makes a huge difference and only running 16psi....my transmission will break before my clutch slips. :eek3:
    btw- I'm installing a gm bcs, biggest top mount I can squeeze under the hood, and modded stock injectors (670cc or so)
  15. project/driven
    Yeah, when I took the stock clutch out it was completely void of clutch material. How much boost are you going to run?
  16. Scuba Steve
    boost? I don't know for sure...but the research I've done leads me to believe (depending on the tune) I should be in the 19-20 area with it tappering off to 16-17 by redline
  17. EtchyLives
    EtchyLives Well-Known Member
    I was kind of shocked at the numbers, too. I ran 200 AWHP on a Dyno Dynamics in my 02 WRX with a 93 Octane Cobb Stage 2 Access ECU (pre-AP Cobb tuning), stock BCS, Stock Turbo, and Stock TMIC. The only "power-adder" I had (other than UP/DP, Tune, IC hoses, and UD Pulley) was an 11.7 pound flywheel.
    With a custom ECUTek tune I was hoping to get at least 210 on that setup.
    Cliffs: 220 is low for your setup.
  18. WRX1
    16psi on a 16g is like running 8psi on the stock turbo. Those turbos love boost. They don't really start making some power till your in the 18+ area. I would run 19 on pump and 24+ on race.
  19. project/driven
    I only made 187 whp on my stage 2 DB tune, which was a little dissapointing as well. It did, however rip off a 13.63 at the track on that set up. It hasn't been back in it's current state I'd be curious how it'd do, because it is noticebly faster. That being said I would like to have a pretty dyno sheet with 250 to 270 whp to hang on the wall.
  20. Scuba Steve
    I'll get you mine...just cross my name out;)
  21. TSTRBOY2004
    I ran 212.3whp with same mods on same brand of dyno
  22. Scuba Steve
    did you have those 19 inch wheels on your car at the time?
  23. curly2k3
    have you gotten a new TMIC yet too? whens it going on!?!
  24. Scuba Steve
    Decided on Turbo XS knock-off top mount IC
    everything should be done by 9/01. I hope
  25. curly2k3
    sweet... who you having tune it?
  26. Scuba Steve
    tune? I don't need no stinkin tune!
    Actually a local top notch tuner. Word is that he's like a jedi master with the 16g....
  27. curly2k3
    Tom? lol
  28. Scuba Steve
    Nope...
  29. curly2k3
    interesting... keeping it a secret or something?
  30. EtchyLives
    Off the shelf map, or custom tune?
  31. TSTRBOY2004
    that wa sactually with an accessport stage2 93 map off the shelf... Tom has tuned it since, and I added one of my hand built x-overs, just also added my custom 4in dp so it spools quicker and stronger.. waiting for next dyno run day....
  32. wall of tvs
    My guess is Steve-o or Russ.
  33. EtchyLives
    Hmmm. Do you happen to know what CF you were running? Mine was 1.15 because I was at 5,500 ft.
    Regardless, those are some GREAT numbers.
  34. TSTRBOY2004
    couldnt tell ya.... was just a dyno run day that the club had.. 3 pulls for $60... no real tuning or testing...
  35. silver03
    Your butt should be IN that chair...workin! ;)
