Looking for cheap toyota 22R shortblock
Discussion in 'For Sale : Car Parts' started by Chux, Dec 17, 2006.
  1. Chux
    so, I dropped the oil pan from my 4Runner today, and all 4 thrust washer halves were in the bottom of the pan. 2 of them were quite mangled. the motor hasn't been run much since it happened, so I'm gong to hope a set of bearings fixes it....but if not, I'm in the market for a new shortblock.
    N/A preferred (higher comp.), but my truck is turbo, so that's ok too. not a big deal if some work needs to be done to it, but it does need to be cheap.
    this doesn't have to come from a truck. I believe Toyota put the 22R in the camry etc. 22r, 22re and 22rte are virtually identical, so any of the above will work.
  2. Chux
    bump...
    I replaced the main bearings and thrust washers in my motor yesterday....with zero improvements. it still sounds like a diesel....so I'm still looking for a new shortblock.
    22RE (fuel injected N/A) preferred.
    I may be running to UPull this weekend...
  3. rabbit
    rabbit Well-Known Member
  4. Chux
    yep....closest one I could find was just outside of Milwaukee
  5. Dynapar
    there was a thing jeff showed me. you email them and then places email you back if they have your part. i will try to find out the places name again it worked really well.
