Looking For Clutch Kit and Flywheel..
Discussion in 'For Sale : Car Parts' started by TheWRX, Mar 18, 2006.
  1. TheWRX
    TheWRX Well-Known Member
    I really need a new Clutch so I am looking for the cheapest Good Clutch Kit and Flywheel...Yeah this is not somthing I expect someone to have in there grage lying around but just want u guys to dircet me to a good site or whatever....The Cheapest Exedy OEM Clutch Kit I found yet was ~$230...and I know flywheels are expensive because I couldn't find anything cheap, but let's see if u guys have any good sources...Oh yeah I want everyting OEM...OEM Clutch and OEM Flywheel is what Im lookin for (Which I have no clue what Im lookin for when Im lookin for flywheels all I see are light wights but I just want stock, so if u can help me and tell me wat brand is stock or wats' the wieght)...All help will be appricated....
    Thanks
    Mo
    2002 Subaru Impreza WRX
  2. AWDimprezaL
    PM drifin240, i think he has a resurfaced flywheel he can sell you, i may be wrong though.
  3. prezawagon
    prezawagon Well-Known Member
    You can just get your flywheel resurfaced, it'll cost about $30. When you're changing your clutch and you get your old flywheel out, just take it to Red Rooster and they can probably do it pretty quick, maybe in an hour or so.
    http://www.red-rooster.com/
    edit: yeah if you can get a resurfaced flywheel ahead of time, that saves a lot of time during the clutch install...
    The clutch kit I had was called AutoSpecialty. But the parts themselves were the exact same brand and part number as the OEM parts I took out. There's no guarantee that the AutoSpecialty kit will always have exact OEM parts, but they will be close to OEM quality I think.
    Joel
  4. ShortytheFirefighter
    I'll also check on what a new OEM setup would cost for you minus the flywheel. There is an updated clutch kit that's supposed to eliminate the cold clutch judder. Probably be cheaper than the Exedy kit you were looking at.
  5. readymix
    The OEM clutch IS an Exedy I believe.
  6. AWDimprezaL
    yes it is, my clutch on my car currently is a 2005 wrx clutch :D it says exedy everywhere on it.
