Looking for some assistance
Discussion in 'General Subaru Discussion' started by Roon, Apr 26, 2009.
  1. Roon
    Roon Well-Known Member
    Hello,
    I am going to be changing my tranny fluid here soon and lack the facilities or the Subaru know how to get it done in a reasonable amount of time. So I am looking for someone who has the things needed to perform the work and would be willing to help me get it done. I was planning on putting "Uncle Scotties Cocktail" in my car and would be willing to bring you one as well, I also have some Surley in my fridge I would bring along. If anyone would be willing to help me out that would be awesome!
  2. bobafett04wrx
    bobafett04wrx New Member
  3. Kevin
    Kevin Well-Known Member
    PM me, i could help you
  4. ej20
    ej20 Well-Known Member
    Its as easy as an oil change but just have to deal with a little tight spot. I highly recommand a small long drain tube. It'll make your day way much easier. I did my 02WRx with a normal length drain tube(8-10") and I spill some fluid. I guess my drain tube is a little big and short.
  5. troysam9999
    troysam9999 Member
    long funnal and drain pan,is very simple if u read riteup could probably do it in your driveway.or any shop will probably hook it up like an oil change if you bring the fluids
  6. Bullwinkle
    Try reading this before using the cocktail.
  7. Ryan
    Ryan Sled drifting master
    Yeah, just to let you know sense I wrote that up I've removed the uncle scotty's out of my tranny.
  8. troysam9999
    troysam9999 Member
    alot of mixed reviews? why did you take yours out.curius i just put it in seams to shift alot better.
  9. mke723
    mke723 Well-Known Member
    try is right, 81 pages? can some one sumerize it please? is it good or bad, cuz i run the grimspeed cocktail, and its close to the same..
    i can help ya, got full shop access in longlake, if ya wanna drive, u can leave your old fluids, and i have the torx bit if its needed, PM me
  10. Bullwinkle
    Summary: Bad.
  11. Roon
    So if Scotty's is bad, may I ask what others are running and with what kind of experiences?
  12. carl
    i would not trust the cocktail if you plan on owning the car very long.
    subaru extra-s is what I personally run
  13. TheHoboMan
    Hmmm, when I put in my cocktail last summer my tranny felt great, nice and smooth, since then I've only put about 4k miles on my car and now I'm feeling a bit of grind when going into 1st, and from 1st to 2nd... -_- I think I am going to switch out the cocktail as well. Is the Subaru Extra-S sold at stealerships?
  14. ShortytheFirefighter
    Yes, the Extra-S is sold at dealerships.
    I ran the Scottys' with mixed results. My 02 WRX did great with it, and I didn't have any issues related to it. However, my 01RS had it in for about 3k miles and has had bearing noise ever since. I don't recommend using the cocktail either. I've been running Castrol 80-90 Hypoy C in there and it's been working great. I'll probably switch over to Extra-S during the next changeover.
  15. Bullwinkle
    Here ya' go.
  16. TheHoboMan
    Thanks Brian and Bullwinkle for linking that post...haha
  17. mke723
    is that 4 different choices, or 4 parts of a better mix?
  18. Bullwinkle
    4 separate choices. In addition to the info in that thread, I'd just personally stray away from mixing fluids...
  19. TheHoboMan
    I had a feeling that the winter cold would have some weird effects on the tranny cocktail..as soon as the cold came and went I started to get the grind..
  20. fischer881
    fischer881 Well-Known Member
    How much does the extra-s run for?
  21. FastMatt
    FastMatt Well-Known Member
    ^I believe it's $16.XX a qt. for non-members and $8.XX for members at the Mtka dealer.
