Looking for undertray for 2008 STI
Discussion in 'Want To Buy : Cars/Parts' started by Herb Miller, Oct 15, 2015.
  1. Herb Miller
    Herb Miller Active Member
    2008 STI undertray is oil soaked; had a leak. Looking to replace it.
  2. predavore
    predavore Well-Known Member
    Fix leak... Wash tray and re-install. Wait until you hit a massive chunk of ice in the winter before you replace.... trust me.
  3. Herb Miller
    Leak is fixed. cleaned the plastic, but material has seen better days. Tried to soak up oil with rags, but still pretty wet. I am assuming the cloth-like material is there to absorb heat of engine and thus avoid melting the plastic tray.
  4. tangledupinblu
    Sounds like a fire hazard. :unsure: I've never seen that before...must be a GR thing?
  5. Herb Miller
    I agree, which is why I'm looking to replace it.
  6. tangledupinblu
    I meant the cloth on it, not the oil.
  7. Herb Miller
    I will keep on working at trying to clean, just was a. Lot of oil.
    Thx
  8. tangledupinblu
    Maybe get some degreaser. Zep brand is a pretty good one. But some hot water with Dawn dish soap should work well. Not Palmolive, not WalMart brand "Dawn"...but the real deal Dawn dish soap. ;)
  9. MNGman
    MNGman Well-Known Member
    ^^^^this^^^^
    Buy a bottle for original Dawn dish soap, and a soft scrub brush. Douse the material with Dawn and water and gently scrub. Rinse thoroughly and let dry. You should be ok after that.
    tangledupinblu and grizbone like this.
  10. Herb Miller
    Thanks to all for the suggestions. I will try the cleaning and see how it goes. I will report back.
