Looking to pickup a wbo2
Discussion in 'Modifications And Maintenance' started by Hallywood, Nov 1, 2007.
  1. Hallywood
    Hallywood Well-Known Member
    Bloomington MN
    For those of you who own one, what brand do you suggest looking into?
    Is the Innovative LM-1 going to be the best bet? I'll be using enginuity for logging/tuning
    thanks in advance
    02 wrx
  2. readymix
    Eloh, El
    Yep, that's a good one.
  3. SubeN'Siren
    SubeN'Siren Well-Known Member
    Siren, WI
    http://www.zeitronix.com/Products/zt2/zt2.htm
    That is the unit I plan on getting when the time comes, have heard good things about it...
    Displays afr, boost, egt's, and probably a few other things if you like.
    I did a search on (nasioc I think) and it looks like you can place the unit display where you're clock is, and it doesn't "clutter" up you're dash with multiple gauges.
  4. Dynapar
    Orono, MN
    I have the innovative wideband (xd-01 gauge set) and it works really well. It can be kinda tricky when you first get it to figure it all out. its a pretty complicated unit for being so small. I am glad I got it though, in fact I am going to be putting it back in shortly.
    I also like the fact that you can wire it into the stock ecu as a normal 02 sensor. very helpful in my situation.
  5. Iroc-Z
    Iroc-Z Well-Known Member
    New Germany, MN
    Talk to Wall of Tv's. I think he is selling his.
  6. gutano
    gutano Well-Known Member
    Oakdale
    There is testing going on to integrate various wbo2's with Enginuity (popular logging software). Personally I would not buy one that isn't on that list. The only one I remember off the top of my head is the LC-1/LM-1 (LM just comes with a handheld device, LC requires a laptop if I read everything right).
  7. 02blubru
    Norwood Young America
  8. Dynapar
    Orono, MN
    From what i remember this is right. the LM-1 is the unit where you can monitor all the settings on the device. the LC-1 is the wideband controller and should come with all their wb02 setups. my xd-01 gauges runs off the the LC-1.
  9. wall of tvs
    dream ftw
    The LM-1 is nothing more than a highly portable LC-1. No wiring to mess with or anything like that.
  10. 02blubru
    You better bring yours with this weekend ;)
  11. mn_sti
    mn_sti Well-Known Member
    Harris, MN
    the LC-1 is a good unit if you don't need something portable. I am logging with enginuity and it works really well. I use a Prosport AFR gauge as well.
  12. Hallywood
    Bloomington MN
    Thanks for all the helpful info, I'm trying to decide if I want the LC-1 or LM-1. Can this be mounted right after the turbo or does it have to go on the tailpipe ?
    I'm sure if I researched a bit I can find an answer..but...
  13. wall of tvs
    dream ftw
    The LM-1 is more of a portable wideband solution. Everything is connected via modular connectors such as the power (via a cigarette lighter adapter) and sensor cables. It also comes with a box that kind of looks like an oldschool GameBoy (but bigger) that displays & records readings and also does all of the calibration stuff. With the tailpipe clamp (like what I've got), you can temporarily clamp the sensor in the tailpipe. You can also take off the clamp and then screw the sensor into any standard o2 sensor bung.
    The LC-1 is designed for a permanent mount. Everything needs to be hardwired in. The vast majority of people that use this also buy a gauge to display the readings. I've also got something like this, but mine is the AEM UEGO unit.
  14. Hallywood
    Bloomington MN
    Thank you for the information!
  15. Dynapar
    Orono, MN
    I put the wb02 from my LC-1 in the DP right behind the turbo. Also the innovate XD-01 kit is pretty neat. IIRC you can do AFR data logging with it. and you can change the colors :) lol
    http://www.innovatemotorsports.com/products/xd16.php I have the standalone gauge kit
  16. mn_sti
    Harris, MN
    +1 for right after the turbo. I am running the Titek catted dp which comes with the bung installed.
