Low power at WOT?!?
Discussion in 'Modifications And Maintenance' started by Underhill, Jun 19, 2007.
  1. Underhill
    Underhill New Member
    OK so Ive noticed that lately at wot I don't seem to be pulling where I think it should be. I have an 04 Sti, 74k on the clock. I am almost due for an oil change, I had a silencer on the exhaust that blew out a gasket by the test pipe, and I just got new wheels. ( last one shouldn't effect power, but just wanted to mention it) Um, I haven't checked plugs or anything yet, just wondering what else I should check.
  2. Taras
    Taras BANNED
    maybe the wheels are heavier than the previous ones.
  3. Nuke
  4. Bullwinkle
    Pull some logs. Butt dynos are deceiving.
  5. Hallywood
    Hallywood Well-Known Member
    Try resetting your ECU - IAM probably dropped
  6. AWDimprezaL
    it doesnt help that its hot as hell out (not today but in general)
  7. Underhill
    clutch seems fine, Ive only had the car only 6mo, so I don't know when plugs were changed last. whats an IAM?
  8. Nuke
    ignition advance multiplier, i believe...
  9. Underhill
    I have a laptop and a cable, but haven't gotten software and done any logging yet.
  10. w_o_t_boy
    w_o_t_boy Well-Known Member
    If your car is pulling timing, its probably for a good reason. Resetting your ECU is just going to make it knock some more.
  11. w_o_t_boy
    Another reason to have an OpenECU training class at Grimmspeed.
  12. Justin
    Justin Well-Known Member
    kinda forgot about this. it should get organized by one of you ecu brainiacs
  13. Underhill
    So where and when, I want to get everything sorted out soon, so I can spend money on + things, not -
  14. Bullwinkle
    +1. Resetting your ECU is probably a bad idea.
    In addition to the hot air being less dense, and making less power, the car will pull timing based on intake temps (if they're high). This will lower power as well.
  15. Hallywood
    You can also have your IAM drop from bad gas, eventually it would go back up but it can take a while.
  16. angusracer
    angusracer Well-Known Member
    you're probably just starting to get used to your car... is this the first time you've owned a faster car?
  17. Scuba Steve
    what about some of the basics.....
    check all you IC hoses and connections. Make sure they are tight and you don't have any leaks.
    previous ower have any exhaust work done, such as aftermarket up-pipe, manifold, etc...? (Yes, even though STi up is catless someone may have thrown an aftermarket pipe in there. ) check for leaks.
  18. Underhill
    after market exhaust, DP, test pipe, CB. I don't know if it has a tune at all. I need to bring it in somewhere. As I said before, I had a silencer on, and blew out a gasket on the test pipe, could that have anything to do with low power?
  19. Scuba Steve
    No, any leaks after the turbo will have little effect on power. However, if you blew out a silencer:eek4: then I would check everything else that is exhaust related...for starters
    leaky exhaust manifold, up-pipe...those two will cause huge loss of power.
    Any weird noises? Louder?
    FYI: If you really need to run a silencer you need to check out the Apexi ATS silencer. It will open when the exhaust pressure increases (WOT). You'll get the power you need at WOT and the quiet ride at lower RPMs. You can find them for 135 plus shipping
  20. Hallywood
    Yeah, you would want a custom tune done on it, or at least get some loggs
  21. Underhill
    Well, now it almost seems to sputter at wot, suggestions? It has been hot, but I would think that would be an accross the board drop, not just at wot.
  22. Hallywood
    MAF possibly? have you tried cleaning it?
  23. Nuke
    what are all mods done to the car, if any
  24. Underhill
    as far as I know, just the exhaust, DP, TP, CB. Im not sure about an UP, I really havn't looked.
  25. Nuke
    Got the turbo heatshield on?
    My car heatsoaked alot without it, and felt like poop driving around.
  26. Underhill
    OK, heat soak, would that happen only at wot, and it seems like more in gears 4+ it happens.
  27. Nuke
    all i'mma say is, my car felt like poop when @ wot at times lol.
    i don't know about yours
  28. WRX1
    Well, just random guess's are wasting time. Log it, or get someone to log it. You could have had some bad gas (where have I heard that before?) and your DAM has been retarded and you are currently running no timing. WOT at 4+ gear would be a perfect example of some high load knocking and a good place for the ecu to pull alot of timing.
  29. Chin
    Chin Well-Known Member
    Now THAT is a gathering I would be interested in! Sorry for the OT...carry on.
