my car just turned 110k miles...just wondering what maintance or stuffs should be done to it ...new timeing belt replaced at 100k. thanks guys...
fuel filter, (probably done) plugs, tranny and diff fluid changed, brake fluid flushed, brakes serviced
where can i get them done for cheap ..?? i did my tranny on the first day i bought the car..i think it was 92k miles
what kinda tranny fluid did you replace it with? and what kind of motor oil have you been using? and do a search on 04 sti suspension to either look for a replacement or you can spray some kinds of silicon lubrication on them so they don't make the clunking noise.
i think the tranny oil were from checker ...and i use mobile 1 5w-30 for every 3000 miles....ok thanks ...i will look for it ...o there is sort of thing that add to the strut??
motul rbf 600 brake fluid was put in @ 85k. there was royal purple tranny/differential fluid in it, put in at 90k.
opps....because 4th gear was grinding so i changed the tranny fluid ...so how many miles do i have to change thebrake and diff. fluid and tranny too????
