Hey guys...I just wanted to get opioions and advice on this TO DO LIST for my 02 WRX w/ 83,000 miles... TO DO LIST... - Oil Pump Seal (Leaking) - Left Cam Seal (Leaking) - Alternator Belt (Worn) - Power Steering Belt (Worn) - Timing Belt (Because of the Leaks) - Water Pump (Don't think I need to but I might since were inthere..) - Brake Pads - Resurface Brake Rotors (Thinkin of buying new) - Replace Brake Fluid, is the same as bleeding (This I am not sure how) - Replace Engine Coolant (If I change water pump) - Spark Plugs (Don't think I need to do This) I believe this is all I am going to do before winter really hits...I hope I didn't miss anythings.....I will post up at somepoint where and when I will do this...If anyone wants to offer a hand I would really appricate it...Thanks.. Mohd.....Thanks..
Do the water pump with the timing belt. Other wise it will bite you in the ass later. Personally when I do my timing belt I am replaceing the tensioner and roller too.
