looking at manifold for my 06 sti... ((allready on - invidia divorced v2, spt catback, cobb stg2 tune) thoughts, suggestions?
Well, if it was me, i would go with a pump and injectors and max out what you have now. You should be able to run 3-4 psi more boost, but you do not have the gas to support the air flow. Also at that point in time, you would be able to add a header to the car and utilize the increase air flow. Currently you are fuel limited for what you have. There is no point in adding anything to the car that will increase air flow until you have the fuel to support it. But that is just what I have learned in the last 5 years of tunning. Russ
thanks for that russ... thats exactly what I was looking for. so now it's back to the ball game of figuring out a turbo configuration. so the list should be pump, injectors, manifold, (tune) turbo, intercooler and attachments? (tune)
