Mannyapolis Build (2013 Subaru Legacy 3.6R Limited)
Discussion in 'General Subaru Discussion' started by Mannyapolis, Apr 25, 2014.
  1. Mannyapolis
    Mannyapolis Member
    Near completion. Next up, injectors, regulator and blower. Hope you like the pic.
    T_riggidy and Windchaser like this.
  2. Nhibbs
    Nhibbs Well-Known Member
    Charging up the electric car?
    tehfuzz likes this.
  3. Mannyapolis
    Mannyapolis Member
    Yes, I added lipo packs and electric motors to give me additional torque and needed a charge. :)
    Nhibbs likes this.
  4. Nhibbs
    Did you buy the supercharger yet? What brand?
  5. Mannyapolis
    Mannyapolis Member
    Not yet purchased. Leaning toward Raptor but not yet convinced I have done my homework on the matter. Need to save up money from my paper route so I have plenty of time to decide. :)
  6. Tash
    Tash Well-Known Member
    Are you planning on building the trans??
  7. Mannyapolis
    Mannyapolis Member
    No, it's not in the cards. Trans will stay stock.
  8. tehfuzz
    tehfuzz Well-Known Member
    Subscribed. :coffee:
    keep us posted :)
  9. Tash
    Hmmm....what are you aiming for power wise?
  10. Mannyapolis
    Mannyapolis Member
    The 3.6R produces about 210 at the wheels from the factory. An upside of 100HP is reasonable.
    Curry likes this.
  11. Tash
    Not bad.....might still not like the torque after a while
    Nhibbs likes this.
  12. Nhibbs
    I agree. Stock gears won't last long if driven hard. Right surly? ;)
    FuJi K and Tash like this.
  13. Mannyapolis
    Mannyapolis Member
    Let's face the facts, a lot is not going to last long on the 2010+ Legacy if driven hard. These cars were built for MILF. So building up the trans may prevent failure but right now I'm not so certain the sheet metal spot welds are going to hold. So go gentle on your Legacy and save the rough driving for the MILF.
  14. Tash
    I'd rather drive both hard
    phi11 likes this.
  15. TMF
    What springs are you on in the pic? Stock?
  16. Curry
    Curry Well-Known Member
  17. Mannyapolis
    Mannyapolis Member
    Yep! Those are the ones. :)
  18. Mannyapolis
    Mannyapolis Member
    Build information. All phase 1 performance mods were professionally installed by DB Performance in Rogers, MN. Working on schedule for phase 2 work which will also be complete by DB Performance.
    PHASE I:
    Whiteline 26mm Front Sway Bar
    Whiteline 24mm Rear Sway Bar
    Whiteline Adjustable End Links Front and Rear
    Whiteline Poly Bushings Front and Rear
    Cusco Front Strut Tower Brace
    Subaru Struts Front and Rear
    H&R Drop Springs -1.3" Ride Height
    Deatschwerks DW-300 340lph Fuel Pump
    DBA T3 4000 Vented Slotted Rotors Front and Rear
    Hawk Performance Ceramic Pads Front and Rear
    Goodridge Braided Stainless Steel Brake Lines
    Custom Brake Calipers Front and Rear
    ATE Super Blue DOT4 Brake Fluid
    aFe Takeda Air Intake
    Air Intake Resonator Delete
    Nameless Performance Axleback Muffler Deletes
    Mid-Pipe Resonator Delete
    AVO Turboworld DBW Throttle Controller
    Custom ECU ROM from ECS Performance
    Savini Avarus AV6 18" Wheels
    Michelin 225/45ZR-18 Pilot Super Sport XL Tires
    Cosworth Low Temp Thermostat
    PHASE II:
    Deatschwerks 500cc Matched Fuel Injectors
    Racing Fuel Regulator (TBD)
    Supercharger (TBD)
    T_riggidy likes this.
  19. SCIFIDELITY
    SCIFIDELITY Well-Known Member
    who the hell made you custom calipers and how much did they cost? feel free to PM is that is too personal.
  20. Mannyapolis
    Mannyapolis Member
    I built them. Started with brand new OEM calipers, tore them apart and upgraded the pistons, seals, boots and slider pins. Installed Russell bleeders on the calipers, painted them red with G2's epoxy and had them installed. I don't know exactly what I put into the set of front and rears but I am guessing $800 - $900. Keep in mind I only did this because I wanted to use the DBA T3 rotors without going for a full set of Brembo brakes.
  21. Qwerty123
    Qwerty123 New Member
    I have (technically the wifes) an 11' Outback with the 3.6R and you have inspired me! Time for me to do some homework...
  22. Mannyapolis
    Mannyapolis Member
    I am happy to hear that. Just be aware that modifying your car to the extent that has been done to mine makes it quite unenjoyable to drive by most peoples standards. My car rides like a truck and is as loud as one too. I like it, most won't. :)
    tehfuzz and phi11 like this.
