At only 43psi we are getting closer and closer to that illusive 4 digit number It seems like it has a lot more left in it, but we need it to hold together for a bit as we are Norwalk bound for the DSM shootout! Any guesses in regards to flywheel horsepower? Keep in mind this is through a 3 speed Ford automatic Also, I want to thank our sponsors that have made this build so successful! The new CNC ported cylinder head from Performance CNC coupled with the Forced Performance Camshafts and Kiggly Racing Valve Springs & Retainers really helped on the top end compared to our previous setup! Active Performance Cooling Straight Line Specialties Fuel Injector Clinic JM Fabrications Forced Performance Kiggly Racing Kaaz USA Performance CNC Jay Racing Ksport USA Motors By Gosh
congrats on the 12.3 ! the car is wooping ass! lol :laugh::laugh: work out them bugs boys and get a good time before it snows
i know that they have been having a ton of problems with the flex plate not fitting right and sheering off bolts into the crank? maybe it f'ed up something in the converter?
Converter issues held us back from leaving the hole hard, but we decided some shakedown runs were in order anyways Considering it did 154.5mph utilizing about 2/3 of the track under power I think it has a lot more in it Can't wait to see what it does with some nitrous to get up on the stall! Make sure your speakers are on pretty loud to get the full effect in regards to when the power came on
We have a new variable stall that just came out it is suppose to be at 4500 all the time then you flip a switch while on the trans brake and it is suppose to go to 5500. The issue is our car does not make any power at 3500 which is where it is stuck at. We are going to spray a 125 shot to get it on the stall and then we should be able to do better than a 2.4 60' LOL We are planning on taking the car to BIR next Sunday I will keep you all posted. BURD
Here is are slip kinda weird HUH R/T.....1.835 60'.....2.444 330'.....6.729 1/8.....9.028 MPH.....114.44 1000'.....10.821 1/4.....12.290 MPH.....154.58 BURD
so soon you will have launches like this... that thing will rip... it does now... cant wait to see when you get the starts dialed in....... [YOUTUBE]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/tuPmeWPKfx0&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/tuPmeWPKfx0&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>[/YOUTUBE]
