Massive Garage Cleanout Thread
Discussion in 'For Sale : Car Parts' started by Hawke, Feb 26, 2011.
  1. Hawke
    Hawke Well-Known Member
    Cleaning out the garage and selling things I no longer use. New items will be added to the thread as I find them and get pictures. Prices are cash & picked up. Located in Shoreview.
    Cobb Catted downpipe. Fits '05 WRX and several other models/years as well.
    $325 SOLD
    STi Axleback from either a 2004 or 2005 STi
    $75 SOLD
    MidPipe not sure if it is from a 2004, 2005 WRX or STi.
    $20 or free with axleback SOLD
    '05 Saab 92x springs. These are stiffer than the standard WRX springs but wouldn't drop the car like aftermarket springs.
    $50 SOLD
    Subaru factory underseat sub. Fits 2007 WRX stereos and probably several others.
    $40 SOLD
    Sway bar from a '05 92x, I believe it's the same as a '05 WRX but not sure.
    $25 SOLD
    Perrin Y-Pipe fits '05 WRX and other years as well.
    $40 SOLD
  2. Hawke
    More stuff
    Rota Tarmac II wheels 17"x7.5" 5x100 48 offset with Goodyear Eagle F1-GSD3 tires 225/45. Fits '05 WRX and more. The tires have about 4/32 tread left or about one summer worth. The whole set has approximately 20k miles on it, maybe less and have only been used during the summer. No curb rash and they are in great shape. Includes spline drive lug nuts and the spline key.
    $500 SOLD
    Kartboy 5-Speed shift lever and bushings combo. This fits a '05 WRX but I believe it fits the years '02-'07.
    $75 SOLD
    Innovate LM-1 WBO2 sensor. Used for approximately 5 hours and always with the sensor powered up. Comes with controller, oxygen sensor, sensor cable, 12V power cable, exhaust bung/plug, serial cable, analog output cable and a CD with the latest LogWorks software.
    $175 SOLD
    Modified stock top feed injectors that fit a '05 WRX and other years. I modified these myself and then sent them to WitchHunter for flow testing. Since they have been used since being tested I don't know what they would flow today but before use the injectors flowed 816cc, 820cc, 832cc and 840cc for a balance of 2.9%. The spray pattern was good on all four as well. I will include the report but I no longer have traceability to the which injector is which. I will also include the spare o-rings seen in the picture.
    $140 SOLD
    GM boost control solenoid. These are not plug and play but do include the harness in the picture so that you can make your own connections. Tubing is included as well.
    $40/each SOLD (both)
    XSPower (EBay) intercooler. Includes the original y-pipe that came with it and the custom one made from a prodrive y-pipe that has better fitment. The custom one requires factory elbows, not included. Fits '05 WRX and other years as well.
    $90
    Gutted up-pipe lightly ported
    $40 SOLD
    Gutted up-pipe missing one stud
    $30 SOLD
    STI splitter that was modified to fit under the scoop of a 92x, not the prettiest modification but functional.
    $40 SOLD
  3. Aegis
    Female
    サイレントヒル
    Go ahead and post them into this thread, I can edit it into your original post. Or if you want to just open a new one, let me know when that's done, and I'll get rid of this one for you.
    I am interested in the sub, too, but I won't be paid for a week. If this is ok lmk :)
  4. Hawke
    That works. Thanks!
    Sub is yours.
  5. Mr.Tran
    Mr.Tran Well-Known Member
    Shakopee
    Does the y pipe come with all needed hardware or just the pipe itself?
  6. Hawke
    Y-pipe is just the pipe. It would need 3 hose clamps to work and I believe the ones from the stock y-pipe fit.
  7. Natural2JZ
    Natural2JZ Well-Known Member
    Minneapolis, MN
    i may be interested in the axleback and midpipe and sway bar.. what kinda miles are on the exhaust?
  8. Hawke
    I'm not entirely sure how many miles are on the exhaust but I would estimate roughly 50k.
  9. tJ914
    tJ914 Active Member
    Hugo
    How's the car sound with the midpipe and the axelback? I might be interested if they're not already spoken for? I assume they'll fit on the car? Ha!
  10. Hawke
    They definitely fit! I think it sounds great, not too loud or droning. The mid-pipe might be the same as what you have since I don't know if it's from a STI or a WRX. Everything but the sub is still available.
  11. Devious Delight
    Devious Delight New Member
    Blaine, MN
    are the wheels 5x100 or 5x114.3?
  12. Hawke
    5x100
  13. BugIedIzzy
    BugIedIzzy Well-Known Member
    Anoka MN
    y pipe and shifter pmed ya
  14. Hawke
    All PM's replied.
    Kartboy shifter is sold.
  15. Hawke
    Perrin Y-Pipe is sold!
  16. Hawke
    I have a buyer lined up for the custom y-pipe on the intercooler package and if I can find a buyer for the intercooler and the y-pipe it came with I'll split them up. Also, the intercooler is lightly ported on the inlet to clean things up a bit and it comes with new inlet gaskets.
    Intercooler:
    $150 with both y-pipes
    $110 without custom y-pipe (will come with the y-pipe sitting on top of the intercooler)
  17. JesseJames
    JesseJames Well-Known Member
    Champlin
    sent ya an email regarding DP, midpipe and axel back via Saab92x.com forum. I included my email address, hit me back. Thanks.
    - James
  18. Hawke
    Injectors are sold!
  19. Hawke
    Price drop on intercooler:
    Intercooler:
    $120 with both y-pipes
    $80 without custom y-pipe (will come with the y-pipe sitting on top of the intercooler)
  20. Hawke
    Downpipe is sold!
  21. Hawke
    Splitter is sold!
  22. Hawke
    Both GM BCSs are sold!
  23. pksublime
    pksublime Well-Known Member
    interested in the sub - pming
  24. Nosser25rs
    Nosser25rs Member
    Mpls
    I'll take the axleback - PMed.
  25. Hawke
    Sub is sold
    Sti axleback is sold
    Intercooler price drop to $90 for both y-pipes plus new inlet gaskets.
  26. Hawke
    Wheels, springs, mid-pipe and sway bar are sold!
    Innovate LM-1 WBO2, Intercooler and up-pipes still available.
  27. Hawke
    Innovate LM-1 sold.
  28. Hawke
    Up-Pipes are sold. Only thing left is the intercooler.
  29. Hawke
    Intercooler sold! Everything is now gone....
