Maxximun Mileage
Discussion in 'General Subaru Discussion' started by Dynapar, May 2, 2005.
  1. Dynapar
    recently i have been monitoring my gas mileage closely, since i just put on an under drive pulley and wanted to see what kind of mileage gains i would get.
    before i was getting 23 - 25 mixed city and highway. on highway normal revs are 3250 at 70 mph.
    now after i ahev noticed mileage of 24.5 - 26 Mixed. this is around 2750 - 3250 rpms @ 70-75 mph.
    anywho my question involve the rev range at which i am cruising.(this is all after the pulley is in) normal driving is around 65-70 mph 2750-3000 rpms. getting solid 25 mpg. a couple days last week i was driving out to coon rapids, and 610 is virtually empty so i was going faster roughly 80 @ 3250-3400 rpms. when i checked my mileage after that i noticed it was arounf 26.5mpg.
    so my question is, is it possible that my car is more effecient at around 3000 rpms then at 2750 giving me more MPG, even though i am at higher revs?
    hope this makes sense.
  2. Grimm
    Grimm New Member
    Not only does it make sense, but I notices the same thing.
    22 city in my nsx 30 mpg at 75-80.
    And the reason is exactly what you thought it was. Your engine is running more efficently (in a way. gear ratio and all), and it is also leaning out. No don't get confused with, "well I know it is the most efficent at 5k so I should do 110... bla bla bla" Wind resistance starts playing in around there too, and it is a cubical function, so it gets big fast.
  3. bikerboy
    The VE or MBP of a motor is typically at the torque peak. That is where it is most efficient. If you cruise at 65 mph @ 2500rpm and the MBP is at 3000rpm you will get better milage there as the car is doing less work and getting more energy per fuel consumed.
    I see 2-3 mpg difference cruising at 80 mph than at 70 mph on my trip to Ga.
  4. Dynapar
    so i believe my car rouhly gets peak torque at 4000 something. so would i see better mileage driving in 3rd gear at 4k vs drivin in OD at 3k?
  5. WRX1
    It is all about torque. In my chev pickup, I have a 6 pack of chips, and my best mileage I got out of it was with the power level 1. I was almost 4 mpg better than the economy chip. Basically it comes down to how hard you have to press on the gas pedal to keep the car moving. A good indicator is a vacume gauge. That tells ya alot about how the motor is working (on and off of boost).
  6. Dynapar
    so on the vacuum gauge it would be the larger vaccum you pull the harder the engine is working?
  7. WRX1
    The more vacume you are pulling, the less the engine is working (throttle is closed more). The harder you step on the pedal (throttle opens), the vacume goes down.
  8. Dynapar
    gotcha
  9. AWDimprezaL
    i have a vaccume gauge somewhere...it helped ALOT when telling mileage it had good average and poor, cant find it though, i had it on my Z34...but on my soob, i cant get better then 22 mpg
  10. kickin_81
    kickin_81 Well-Known Member
    My little "scan gauge" gadget tells me exactly to the tenths how much Gallons Per Hour and the Miles Per Gallon I'm using. Martin, if you would like to use it for a week for your testing, I'll gladly let you use it. But you have to have an OBD-2 port under your steering column. It only works for OBD-2 vehicles.
    <u>Here's a small breakdown on what I've noticed on my 2000 Subaru Impreza 2.5 RS at cruise:</u>
    I get ~2.2 GPH at 65 mph with 195/65-15 winter tires and 92 octane (non-oxy)
    I get ~2.0 GPH at 65 mph with 195/65-15 winter tires and 87 octane
    I get ~1.8 GPH at 65 mph with 205/50-16 summer tires and 87 octane
    In general, wind resistance, throttle, inclines/declines, load, etc. all affect your fuel consumption. The more resistance put against your motor's rotation, the more fuel you're gonna use. The more air your motor injests, the more fuel you're gonna use.
  11. AWDimprezaL
    in soobs...obd2 started in 1995, he should be just fine
  12. WRX1
    The best I have ever got in my car is around 31 on the way to chicago. We were just crusing at 75. Now, my milage did go up with my new turbo because I have less back pressure off boost (more low end torque).
  13. AWDimprezaL
    i thought more backpressure at lower RPM makes more torque..because on my dirtbike, i have a supertrapp muffler, it said add disks for upper rpm power, and remove disks for quieter and more torque...is it different in cars? my dirtbike is a 4 stroke btw
  14. WRX1
    I still have backpressure, but not as much. On your dirtbike, it will have alot less backpressure than my car. You don't have to try and spin up a turbo, so that creates back pressure. You bike is just some straight pipe and a muffler on the end.
  15. AWDimprezaL
    i see, thanks for the info:)
  16. Dynapar
    after implementign some new driving techniques, i have noticed dramatically incresed mileage. this time @ about 1/2 tank of gas i ahve 195m. it came out to be like 28.3235MPG or somethign like that. this was mostly highway driving with some city.
    this new technique includes:
    slow accelrations
    Cruising @ 1/32 - 1/16 throttle
    stop over longer distance (coasting more)
    Things to try next:
    nuetral on downhills
    slower turns
    drafting
  17. WRX1
    Install a vac gauge. The will tell you alot about how the motor is running. Basically on the freeway you want to have the highest vac at the fasted speed. My new truck likes the 70-75 mph range, and my car is right around 75. Thats where you can hold the highest vac (least throttle) and most speed. Drafting definitly works (visable with a vac gauge) on freeway driving. As for the neutral on down hills, I would leave it in gear. I think you would use less gas. I know the newer wrx and sti does a fuel cut (cuts the injectors on coasting), and your car might be the same.
  18. Dynapar
    neat, i will look into getting a gauge
  19. Xcelor8
    Xcelor8 Well-Known Member
    Yeah I get the best gas mileage in my truck at 74 MPH, at 75 it seems to go way down, I can't explain why, and I don't travel too much at lower speed than that, unless it's city only, but when I've traveled at 60-65 mph it didn't do as well.
    My car gets 20, no matter what I do.... I can't figure it out.
