Maybe a bad axle with MNSubaru's FXT
Discussion in 'General Subaru Discussion' started by kickin_81, Aug 10, 2005.
  1. kickin_81
    kickin_81 Well-Known Member
    St. Paul
    I have noticed a small collection of tranny-like fluid (thick and yellowish) on the bottom of my tranny at the install day. I wiped it there. Recently, I changed my oil and found that it collected again at the same spot. I'm a bit worried.
    A little research has found that this is a common problem with newer Subaru models. Bad axles. Has anyone have this same fluid collect at the base of their tranny, too? :?
  2. tbone
    tbone Well-Known Member
    MN
    Stop racing like a granny
  3. FuJi K
    St. Paul, MN
    it must be that NEW axle spline thing they changed. Supposely it's the axles that go INTO the tranny than like your old RS where the axle splines come OUT from the tranny. I dunno....
  4. kickin_81
    St. Paul
    It didn't taste like pee, so it must be the tranny fluid leaking past the axles. Thanks, Fuji. And Tbone, I granny shift whenever I can just to piss you off. :eek: :p
  5. tbone
    MN
    I hope it is not serious
  6. LVT
    LVT Well-Known Member
    t3h f4sT
    take it back to the dealer! it still has warrenty right?
  7. subi_2.5rs
    subi_2.5rs New Member
    ghettofornia
    not anymore.....mods......
  8. ShortytheFirefighter
    It depends on what the repair is, if it's unrelated it might be covered.
  9. Chux
    Independence, MN
    is the boot torn? poke your finger up there and see if it's torn...I would be the master of axle problems.....
    the only way you could be having axle grease leaving the joint is boot failure. if it's from the splines, it's a seal on your tranny.
  10. kickin_81
    St. Paul
    I couln't find any tears in the boot. I'm sure it's under warranty. :)
