Methanol Injection?
Discussion in 'Modifications And Maintenance' started by Paul Revere, Nov 17, 2006.
  1. Paul Revere
    Hey guys this is my first thread so first I wanna say hello and thanks. Now to the point I've been looking at this website http://www.snowperformance.net/default.asp and im not sure if I should believe it or not. I found this quote and it sounds to good to be true.
    "Incredible! After installing the Boost Coolerâ„¢, I can run 8 psi
    more boost and more timing with no knock!"– Reinaldo Maloon, ’02 Dodge Spirit Turbo.
    I just want some insight on what others think.
  2. hofit
    hofit Well-Known Member
    It's definitely true. It'll raise the octane of your gas. Lots of STI's on IWSTI are running 30-50 horse more at the wheel. I'm ordering an alkycontrol kit from alkycontrol.com.
  3. Xcelor8
    Xcelor8 Well-Known Member
    I know discopope has/did have one on his sti.
  4. ILLICITWERX
    ILLICITWERX New Member
  5. fobiawrx
    fobiawrx Fabiola
    oooooo.. do it^^^^^^^^^^^
  6. ScoobyTodd
    ScoobyTodd New Member
    I had an alkycontrol kit on my 05 STi...awesome!!! My best advice to you is prepare for injection with proper gauges and your setup, get a proper tune, and choose your kit wisely. The best failsafe is an over designed kit and a smart operator.
    For reference on LSE's Dyno Dynamics I hit 273whp and 315wtq with a TBE, Accessport, 50/50 meth/water injection, and a TopSpeed tune. The torque was awesome once the injection hit!!
  7. Hallywood
    Hallywood Well-Known Member
    My roommate just got his h20/meth installed in his eclipse. Boostin 24psi with no problems. Before he was at 18psi.
  8. Shibbs
    ^^ Hopefully not on the stock turbo! Oil seals leak bad on those above stock boost.
  9. Hallywood
    ^^^nah, just the big 16G. Pretty much every bolt on possible, nothing done internally
  10. WagonsRock
    WagonsRock Well-Known Member
    What is the downside to the injection? Why don't you see it on factory setups?
  11. Sogonerg
    Sogonerg Anteater
    ^The same way why Nitrous isn't a factory setup.
  12. Sogonerg
    Sogonerg Anteater
    If not used/modded correctly it can be dangerous for the car and the person in it.
  13. RichWRX
    RichWRX Well-Known Member
    and you have to remember to keep alcohol in it, that little tank they give you goes empty real fast
  14. Dynapar
    ^ thats the main reason i wont get it. what happens if you run out? my guess is bad stuff. unless you have a fall back map for stock.
  15. Sogonerg
    Sogonerg Anteater
    ^That's y u have different MAPs/Selector...That's y I'm planning on having a 93 map, 110, & 110 w/Meth.
  16. RichWRX
    Im useing a 3 gal tank, just have to remember to check it once in a while
