might have to say goodbye to my engine...
Discussion in 'Modifications And Maintenance' started by vanddelor, Dec 20, 2007.
  1. vanddelor
    vanddelor Well-Known Member
    for those who don't know, it's an 02 wrx with stage 2 and a tune
    so...i was coming home from st paul today and was doing some sprited driving. while i was in fourth, when i let go of the gas, instead hearing my bov go off, there was a big flutter. after that, i got off the highway and everytime i shifted, bov don't go off but only the flutter sound. i got home and put the stock bpv in and took it for a drive. it still made the noise but this time, there's a clicking in there with the fluttering. i thought about if it's the y-pipe might of gotten loose, but i was hitting target boost fine. so i let the car cool down and went to start it again, now at idle you can hear the clicking and it's LOUD....coming from left side of the engine. any other thought of what it might be..??
  2. Paul Revere
    Like this?
  3. hella_sti
    hella_sti Well-Known Member
    so everyone with a 2.0 should run at least 10w-30??? I'm scared since I'm running M1 5w-30.
  4. vanddelor
    yeah...like that...what do i do now..?...is it safe to drive..?
  5. Taras
    Taras BANNED
    rebuild the engine?
  6. piddster
    If you stop driving it now, you could rebuild it. Otherwise you'll need a different motor.
    I vote 257 shortblock.
  7. LilRed
    LilRed Well-Known Member
    but if you go with the sti shortblock dont you have to pnp the wrx heads cause they need to flow a lot better than stock?
  8. piddster
    The mass airflow sensor takes care of any issues related to how much air is flowing into and out of the motor.
  9. LilRed
    so you are saying if i wanted to i can just swap in a shortblock and wam bam i'm good?
  10. piddster
    All EJ series shortblocks are interchangeable with all EJ series heads(and associated hardware), for the most part. If he wanted to, he could use an EJ22E for $150 from the junkyard. Not that it would be a good solution, but you could.
    If rod knock is the problem, a new shortblock would take care of it. Otherwise rebuilding it would be cheaper parts wise, but its not for the faint of heart.
  11. AWDimprezaL
    sell the car to me :)
  12. piddster
    ^ shouldn't you be in bed?
  13. Dynapar
    interesting idea. the wrx heads would drop the compression probably into the 8:1 range. not ideal, but an interesting cheap fix (EJ22E FTW!)
  14. curly2k3
    lol, i was doing the opposite, WRX short block with RS SOHC heads.
  15. vanddelor
    so if i do want to go with the sti 257 block, do i need sti cams and ecu to go with it..?
  16. curly2k3
    STI cams are different due to the AVCS
  17. readymix
    The WRX heads stock will bolt up and work just fine on an STI shortblock. You don't need anything really special to do it. I would go with a cometic head gasket if you do go that route. The 8:1CR of the EJ22E on WRX heads would be more than ideal since the WRX's stock CR is 8:1. But I don't know if that EJ22E 8:1 is actually the case because I've never done the math on it. It would be interesting to see though. THe EJ22E isn't much different than the EJ20, both are the same stroke and both are open deck blocks.
  18. AWDimprezaL
    no, you dont need the cams, you can use your existing everything, it will be a potent package
  19. AWDimprezaL
    and word to the ej22e being a very cheap upgrade, the only downfall i could see would be you would need a tune, but you would need that for a 257 anyways
  20. vanddelor
    so a stock sti ej257 block pretty much bolts rite on to my heads and tranny with no problem and i shouldn't need anything else..?
  21. curly2k3
    and from what i could tell, all the accessories and sensors swap over without much effort at all
  22. vanddelor
    how long...if i drive very carefully will this last me..??..because my student loans don't come in til around jan 14...
  23. piddster
    well, you'll probably throw the rod if you drive on it for too long, and that can cause even more damage. do you have another vehicle?
    Oil pump, water pump, timing belt gear, crank pully, coolant crossover, etc will all swap over from your EJ205 shortblock.
  24. Mike Wagner
    Mike Wagner New Member
    Would you see any performance increase with the 257 or are the heads the bottle nexk?
  25. AWDimprezaL
    no the heads flow really well, you would gain alot of low end torque because it ups the CR a couple points and its larger displacement/greater stroke
  26. readymix
    I'm running a 257 with WRX heads and the CR came to around 8.7:1. WRX heads will flow just fine up to around 450-500whp. Porting them will obviously net you some gains and may help with spool and such. But if your goals don't exceed 400whp, WRX heads will work just as well as any other heads.
  27. FuJi K
    port them anyways!!!! lolz Since they're OUT, might as well! hahahahaa (I know nothing!)
    don't drive anymore. THe more you drive, the more shavings there are going to be in the oil pan, and the oil pick up will pick it up and throw it into the pump, and the oil cooler....then the filter. PARK IT!!
  28. readymix
    Also great advice. The longer you drive it, the worse off you'll be.
  29. wall of tvs
    You are going to NEED a good tune and hope that your engine doesn't throw phantom signals that the ecu will think is knock.
    IMHO, get a UTEC if you decide to go this route.
  30. wall of tvs
    Please......so with that rationalle, you should just be able to slap on a gt35r and let the MAF take care of things for you? :eek4:
    I don't think so. The car WILL need to be retuned.
  31. vanddelor
    alrite...the car is sitting in my garage rite now...lucky enough...it's winter break and dont have to drive to school...only to work though...but anyways...in the process of taking out engine tonight...this is my first so it'll be interesting...any pointers or tips out there...and does anyone have a 257 block they wanna sell..??..or else i'm just gonna go on nasioc and get one off there...anything else let me know...and if anyone wanna lend a hand...that would be awesome...
  32. Ronnie@RSmotors
    No you don't unless you prefer to have them.(about the sti cams)
    If you're engine is knocking now. It will cost you almost the same to rebuild it that just to buy a STI short block. STI shortblock is the way to go considering the cost and upgrade from a 2.0 to 2.5 You better hurry thou since non of the local dealers will sell you an STI shortblock anymore unless you own an STI. Last one I did we had to order from a dealer in Colorado.
  33. vanddelor
    ok...almost everything is off now...just need to go buy a crane so i can lift out the engine...man...i should really buy a block first...now i have everything out and nothing to go in yet...anyways...thanks for all the help and suggestions...
  34. vanddelor
    alrite, since i'm taking everything apart anyways, mine as well do the turbo too.
    power wise...i would like to get somewhere in the 330-350whp...
    turbos i'm looking at are the 18G and 20G...
    injectors somewhere between 750cc-800cc...
    perrin ss fmic
    walbro fp
    a very good tune...
    anyother suggestions...??
  35. piddster
    I meant all things being equal besides the shortblock.
    Maybe I give the factory ecu too much credit...
  36. TRUBLU
    TRUBLU New Member
    just a little off-topic to the person who questioned oil thickness. In reality you can use either 5-30 or 10-30. The 10-30 is only thicker when the oil is cold. Once both oils are at operating temp they are the same viscosity.
  37. vanddelor
  38. curly2k3
    and a retune basically, yeah should cover it i think
  39. vanddelor
    oh yeah...what head gasket do i buy..??...the sti gaskets because it's an sti block..?? or wrx heads gasket because it's wrx heads..??...cometic have head gaskets that are 1.0mm/040...and 1.1mm/045...and 1.3mm/51...which one do i choose..??...or should i just buy the oem head gaskets for the 2.5l...??
  40. curly2k3
    i think Jason used the STI cometic ones...not sure tho to be honest, i think* either would work
  41. vanddelor
    and alot of people on nasioc is saying since i have it out already...to have my heads checked too...so i'm gonna need you subie techs out there for this one...
  42. Ronnie@RSmotors
    You need the sti gaskets. You also need to clean the heck out of anything/everything the oil touched. If you're engine knocked, most likely you have all kinds of bearing shavings mixed with your oil. Ignoring this will result in another knocking engine.
  43. piddster
    ^ THIS
    Cleanliness is a huge part of engine assembly. I learned the hard way...
  44. vanddelor
    one of the engine mount nut is rounded off...any tips on how to get this sucker out..i've tried heating it...and it's too tight of a space to cut it off....
  45. FuJi K
    is it UNDER the engine crossmember???? come on.....I haven't stripped one of those ever...well at least not yet. lolz The previous WRX engine build (not mine) the owner stripped his. Poor soul....
    How rounded off is it??? If it is, you're going to have to unbolt the engine mount from the engine. This requires a WRENCH to get the one between the engien and crossmember. The other bolt is easier because it's towards the front of the engine. Gonna be TIGHT!!! Need to take off uppipe, downpipe, turbo, possibly headers.
