I have some items sitting around from a few rally car builds that hopefully someone could use. 2 OEM 6 disc indash stereos, one 03 wrx and 1 06 sti. $100.00 each 1 set of OEM STI front and rear speakers. $100.00 2 passenger air bags. $100.00 each one 03 WRX MOMO steering wheel with airbag, $200.00 06 Pia light pod without lights, NEW 350.00 for MNsubaru. new retail at 576 http://www.specialstage.com/classifieds/showproduct.php/product/1378/cat/18 SOLD! 06 Group N gravel brakes, calipers, and rotors. used. New retail $1800.00 MNsubaru $900.00 http://www.specialstage.com/classifieds/showproduct.php/product/1376/cat/18 06 OEM STI struts with springs and top mounts. 24k miles. $400.00 http://www.specialstage.com/classifieds/showproduct.php/product/1377/cat/18 Also 2 AC compressors. one 03 with 42k miles one 06 with 24k miles. $100 each? 06 ac lines $? 06 Seat belts front and rear $? Misc interior plastic, a pilar, b pillar, Rhino lined headliner, Parcel shelf. $? Doug Davenport www.davenportracingusa.com
I can not be perfectly sure. But I do not know why they would not. the ones I have are from the dash to the compressor only. Doug Davenport www.davenportracingusa.com
wonder how much work it would be to form the 06 pod onto an 04. after last weekend we've found the flaw in non-hood mounted light set-ups
I need the one that crosses along the firewall behind the intercooler. part #73422FE011 SUCTION HOSE & ORING (ASPIRATOR) . It is possible that the part (#73422FE050 for 06) is different for the model year, so I don't know if it will or will not work for an 04. depends how much you need for it, then I can see if it works.
Are the '06 belts the same as the '07's? I've got '07 seats and '05 belts and they're not compatible.
