Misfire in cylinder 4
Discussion in 'Modifications And Maintenance' started by wings_23, May 9, 2008.
  1. wings_23
    wings_23 New Member
    I have a misfire in cylinder 4. It has shut itself off twice. I have replaced spark plugs with subaru oem. I had the coil pack switched to a different cylinder and the cel stayed on 4. Bikerboy pressure tested it at 130,130,130,and 132. I know those are a little low but not horrible. I ran a bottle of Lucas through a tank(the code actually started 2 days after that bottle) and then I have gone through a half a tank of techron. I did fill up almost every time with Holiday gas. I used mobile 1 synthetic everytime I changed oil.
    The maintenance manager at Morriss BP suggested replacing the injector in that cylinder as my next attempt. I am very low on funds, so that is why I am only getting one done.
    Anybody have any idea or experienced this in the past?
    05 sti with no mods what so ever. 61,000 miles. I drove it like an sti but I never have launched or raced on a track, I baby it for the most part.
  2. Bullwinkle
    Change to BP 92, and see if it helps.
  3. wings_23
    wings_23 New Member
    the tank that is in there now is shell, I am never putting holiday gas in again. Could it really be something as simple as changing gas? Its idiling a little rough. Also I revisited my rant about my mpg going down and its only 20-30 miles per tank different than last summer.
  4. Jackstand
    Jackstand Well-Known Member
    Yea gas can make big difference my car wouldnt start one time when i got a bad tank of SA gas.... Never again only BP and Shell
  5. curly2k3
    yes, gas can make a huge difference. if you have been running Holiday i would personally run some Seafoam through there to clean out the system and keep running BP or Shell now
  6. wings_23
    wings_23 New Member
    There is a bottle of techron in there now, should I wait until this tank is gone before I put seafoam in??
    Any other ideas besides gas?
  7. tux121
    tux121 Well-Known Member
    I've heard RX-8's had problems with Shells 92 Gas. Not sure on subies though. Just something that may relate even though they have no pistons.
  8. driftin240
    driftin240 Well-Known Member
    Yes they do, they just look like Dorito's, and they rotate...
  9. curly2k3
    those crazy flopping Doritos of doom with their silly apex seals. i lawl at them.
