misfire?
Discussion in 'Modifications And Maintenance' started by subie_wannabe, Feb 28, 2007.
  1. subie_wannabe
    subie_wannabe New Member
    Is misfire when your exhaust sometimes sounds like a popping sound, because when I shift from 1st-2nd i hear a pop sound coming from my exhaust? Is this good or bad?
    How can I fix this?
    thanks
  2. AWDimprezaL
    year model and mods would help
  3. subie_wannabe
    its an 02WRX with tbe and running cobb stage 2...other then that all other parts are stock.
  4. AWDimprezaL
    its not uncommon, do you have an aftermarket blow off valve?
  5. Rexwagon
    Rexwagon Well-Known Member
    BOV cause it. which is normal.
  6. subie_wannabe
    oh forgot to add that it has an hks ssq bov...if thats the case thanks :)
  7. AWDimprezaL
    yes that would be the issue
  8. subie_wannabe
    is it a bad thing? and do all bov do that?
  9. AWDimprezaL
    rich condition between shifts, you are probably shooting flames too, its fine
  10. esperunit
    esperunit Well-Known Member
    yep the unburnt gas is coming all of the way through and igniting in your exhaust, making a popping noise. when your blow off valve is going off it is removing metered air that the engine is expecting is coming through the intake, so for that period of time the BOV is acting the engine is getting fuel for air that isnt there, and its not burning completely.
  11. subie_wannabe
    alright thanks guys for all the help
  12. chokin
    chokin Well-Known Member
    haha backfiring !! mine does that too also when im down shifting.!! which is cool tho ...i think
  13. Se7enrex
    Se7enrex Well-Known Member
    Not to be a **** but tech. its an "AFTERFIRE"
