missing and smoking like crazy!
Discussion in 'General Subaru Discussion' started by AWDimprezaL, Apr 12, 2005.
  1. AWDimprezaL
    i have a cylinder 3 misfire, with a tick, im thinking either valve guides (notorious on single port 2.2 heads) or an injector, because its pouring gas out of the exhaust, and i mean liquid gas, im gonna try my turbo injectors and see if it takes the miss away, i wont be able to go to redline, but it will at least drive
  2. FuJi K
    check injector connectors, and the like. Spark plugs, wires, the coil pack. Wish you luck!
  3. AWDimprezaL
    im fairly certain that its cyl 3 injector, because when i pull the connector off, it still misses of course, but it doesnt tick, and seems to smooth out a bit ( as smooth as a miss can be!) so i'll try my other injectors tonight,thanks fuji!
  4. kickin_81
    kickin_81 Well-Known Member
    Good luck with it. I'm clueless.
  5. Dynapar
    my dads subie has the 2.2 and he threw a code for missing on cylinder 3. it was a bad plug wire. new wire in and now no more probs. good luck diagnosing it.
  6. AWDimprezaL
    well, i put the right side turbo fuel rail on, with injectors, and it seems to run fine, so im ordering a new injector, also it stopped smoking, 80 bucks sound ok for an injector?
  7. Dynapar
    i bet if you scrounged i club or sometign you could get one for liek 10 bucks.
  8. AWDimprezaL
    too late, it runs perfect now though
