Missing restrictor pill
Discussion in 'Modifications And Maintenance' started by 1_sic_rex, Jul 31, 2007.
  1. 1_sic_rex
    1_sic_rex Well-Known Member
    SO we found out (thanks to Idget) that i was missing a restrictor pill in my 02 WRX. My question is could that be causing a lean on bank 1 code? p0171?
  2. WRX1
    Nope, the pill is there so you can hit target boost with a bleed system.
    List of mods?? Lean on bank 1 is usually a fuel trim code, so if your fuel trims are too lean for a intake or something like that.
  3. 1_sic_rex
    I have a stage two flash at 17psi with a turbo back exhaust.
  4. Bullwinkle
    Is the car making that boost target?
  5. blackozone
    Without the restrictor pill the car is hitting limp boost at 9 psi. So until he gets that little pill, no.
  6. Bullwinkle
    Yeah, I was little confused with his previous statement. Now go get one. :)
  7. w_o_t_boy
    w_o_t_boy Well-Known Member
    If you're getting a lean on bank 1 code, the last thing you want to do is turn up the boost. Get somebody who knows what they're doing to hook a computer up to your car and figure out exactly what's happening.
  8. wall of tvs
    The first thing I would check for is a massive pre-turbo/post-MAF intake leak (assuming the stock airbox).
  9. blackozone
    he's got a stock airbox, yes.
  10. 1_sic_rex
    Thanks lee.... yea stock airbox.... i pretty much drowned my car in soapy water lookin for boost leaks and i found nothing.... As for having someone with more knowledge look at it..... I live in rochester and havent found anyone willing to help. So if there are anytakers, i am willing to pay.
  11. wall of tvs
    Did you check the bov return hose? It's pretty easy to overlook that hose since it's so buried.
  12. 1_sic_rex
    Check everything when we pulled the intercooler off. Then double checked when we put it back together... it also has a bad hesitation at like 4500rpms.
  13. DISCOPOPE
    DISCOPOPE Well-Known Member
    well, either you have a leak, or a bad front o2 sensor.
  14. blackozone
    Umm... I'll help... Thanks for asking, ya jackass...
