As the title says I have a set of W25 dual AVCS heads for a 2008 and up STI. These heads were completely rebuilt which consisted of: Hot tank Bead blasted Hot tanked again with all galley plugs removed and cleaned Seats cut Stock valves refaced New valve guide seals Cylinder heads resurfaced BC spring and retainers (BC0600) Valve clearance set to new cams BC stage 3 cams (BC0624) These heads are ready to be bolted on. They were run in on an engine that was removed and parted out to run a sleeved block and C&C heads. Total run time was 50 miles when removed. Please PM with any questions you may have. 2500.00 OBO plus shipping and paypal fees
