Modded Sidefeed Injectors
Discussion in 'For Sale : Car Parts' started by Moleness, May 8, 2010.
  1. Moleness
    I have a set of modded sidefeed injectors. They fit 04-06 STI's for sure and any other sidefeed Subaru. (maybe LGT or FXT? Do your homework ;) )
    Three were good, and one ran rich. I purchased a newly modded/cleaned injector that matches the set to replace it.
    All 4 have been cleaned and flow tested, and not installed since, so they are as new as modded injectors get. A new set goes for $390.
    SOLD
    Original Flow sheet from when Wichhunter serviced the set on '06 (#1 went on the fritz):
    The injector I just bought to replace #1, and it's flow sheet:
    Recently tested on a high-reading machine locally, not installed since. This is where I found that #1 was staying open too long or something.
  2. jdm4you
    jdm4you New Member
    How many cc's are these's?
  3. Threshld1
    Threshld1 Well-Known Member
    cc/min @ 43.5psi 1020, 930, 930, 930...
  4. jdm4you
    jdm4you New Member
    Wow!!! Ok. Way bigger then I need. GLWS though!!!
  5. Moleness
    According to witchhhunter, who serviced them a couple years ago, they are 824-832cc's. Like I said, some sort of variable caused higher than normal readouts at ravenworks
    BUMP for me having another injector coming that will match the set, so I will be selling a matched set and the asking price will be updated accordingly ;)
  6. john
    john Well-Known Member
    I run a set of modified sidefeed stockers in my '05 LGT, which are rated at 816cc/min. Mine were modified by Perrin.
    Good price - someone buy these.
  7. Moleness
    Bump!
    I now have a full, matched, clean, good as new set ready to install. See OP for details :)
  8. KSAL
    KSAL Well-Known Member
    I can vouch for these things. They were in my STi for a few years until I moved to 1260's. They will make GREAT power for anyone looking for it. I made 491 on racegas and they held that just fine. Anybody looking for a good deal its right here!
  9. Moleness
    Bump for reasonable offers...I may even be talked into helping with install ;)
  10. Moleness
    I will take $316.50 if i get it by sunday.
  11. Moleness
    this!!!
  12. vangstaboi86
  13. Moleness
    Bump for lowered price...
  14. Moleness
    Sold, yay!
