Most of these parts came off a 2001 2.5 RS Sedan, MT, 18x,xxx miles. 2001 2.5 RS parts: $40 - OEM Grille(silver), some typical blemishes and 1 missing clip $120 - v3/v4 genuine JDM STI spoiler, unpainted, comes with light and all mounting points in tact $100 - "carbon fiber" console trim/cubby/shift surround, 2 light cracks in center console that dont go all the way through, light blemishes in a couple spots but barely nocite $5 - radio brackets $0 - RS radio harness, cut so slightly shorter wires $5 - HVAC controls, no wires, good shape $10 - OEM amber bumper signals $0 - double din cubby $0 - ebrake rubber surround, great shape $50 - mint R fog light, glass has no imperfections, slight discoloring on bulb shroud $0 - broken glass L fog light, shroud just needs cleaning before glass is replaced, still works $40 - cluster and harness, slight imperfections $5ea - hazard and defrost switches, mint $0 - change holders for center $20 - GC Sedan 'altezza' tail lights with harnesses, some moisture got in the right side(see pictures) $10 - driver side fender(see pictures) $10 - dash center (radio mount), some wear around the trim area, pictured $10 - working cup holder, not sticky $40 - glove box, some surface scratches $0 - center console arm rest, broken tab, scratches and pint holes on pass side $10 - cluster surround, light scratches on inner right side $75 - near mint condition dash $250 - set of 4 205/55/16 Toyo Eclipse A/S tires with 90% tread left and 5x100 wrx wheels with some road rash $50 - AEM short ram intake, hoses and used filter I dont have detailed photos of the following but can get them if you are interested. $20 - oem exhaust manifold $100 - set of 4 complete; axles, hubs, struts/spring assembly, brakes $250 - 5-speed and ECU, had very minor play in the shifter, had a crappy clutch when i bought it so i never beat on it and it shifter well, throwout bearing could be replaced along with the bushing for a cheap replacement trans. $20 - M/T oem radiator, good condition $20 - drive shaft $40 - rear end R160 Pictures below
Sorry. The following items are pending sale: 5 speed Rear end Drive shaft Axles/hubs/brakes/suspension assembly AEM intake I will message you if the sale falls through.
Updated list, big ticket items are gone, added a few small things. I'll bundle the dash/ glove box/center/ carbon fiber trim/ for $150.
