Multiple CEL's
Discussion in 'Modifications And Maintenance' started by MNAutomatic, Jun 24, 2006.
  1. MNAutomatic
    MNAutomatic New Member
    I'm on the westside
    So I had a great time last night driving out to my buddys cabin. I got three different check engine lights and my car died on me three different times as well. I pulled P0545 (EGT Sensor Low input), P1301 (Fire Due to Increased Exhaust Temp), P1544 (High Exhaust Temp). I reset my ecu each time it happens but the CEL's come back after about 20 minutes or so of driving. My car is sitting at my buddys cabin but which is about an hour away. Basically my question is, Is my car capable of being driven back or should I just find a trailer and bring it back that way. My second and bigger question now is, what do you guys think is wrong with it? I think its just the exhaust sensor but im not sure. Any help will be much appreciated, especially in finding a trailer if I am not able to drive it at all.
  2. 02blubru
    Norwood Young America
    Do you have a tow vehicle? If so I might be able to help you out with a trailer...
  3. MNAutomatic
    I'm on the westside
    Yeah...My mom drives a Range Rover Sport and my Father drives an Escalade so I definately have a vehicle to use, just no trailer. If you can help me out I would very much appreciate it.
  4. kickin_81
    kickin_81 Well-Known Member
    St. Paul
    It sounds like you need a new EGT sensor. The only difficult thing about replacing it is that it's in a tight spot on the uppipe that may require a lot of wrenching. Nathan can help at his Meineke shop (after hours... shhhhh.) for a little $$.
  5. 02blubru
    I will check with my dad and see if we can use his car trailer.. where is the car at? How many miles away?
  6. MNAutomatic
    I'm on the westside
    My car is currently sitting in annondale...about 15 minutes or so past buffalo on 55 west. If you dont wanna do the drive with me I would be able to return the trailer same day no problem. Of course I would take responsibility for anything that would happen to the trailer while in my possesion.
  7. bikerboy
    on the water looking for the sandbox
    Unplug the EGT probe and drive it home. It will not hurt the car.
  8. 02blubru
    mnauto, you can do what bikerboy suggest or we can make the run.. my dads car trailer is in buffalo at his house. When were you hoping to do it? My schedule is booked as in a month I tie the knot....
  9. TSTRBOY2004
    may be your convertor crapped itself and is blocking the exhaust flow causing it to overheat ... or is running way to rich and overheating your syste, which in turn cookeds all the sensors too.... maybe... I dont know...
  10. MNAutomatic
    I'm on the westside
    im catless so im guessing the sensor got cooked. Now the question is, where is the plug?
  11. WRX1
    Over there
    You can just follow the sensor leads up from the uppipe, but they will lead to a little black plug on the pass strut tower. I think it is the plug right under the drl resistor. Also, you can use a 2.2k resistor in the car side of the plug and completely bypass the stock egt. Also, you can drive the car, it will be fine.
  12. 02blubru
    sounds like you can drive it.
    Let me know and I will check on the trailer for you...
  13. MNAutomatic
    I'm on the westside
    Well got out to my buddies cabin again last night for a night of some fun and saw my car for the first time in a week, my god she was dirty. I unplugged the EGT plug on the strut tower, the one leading to the up pipe, and my car ran like a champ all the way home. Well the CEL light was on, like I expected, but when I got back into my car about 2 1/2 hours later to go to work, the CEL was off. I am looking for the 2.2 ohm resistor but am running out of luck too. Think I should be worried at all? I never reset my ECU or anything to clear the CEL, it just dis appeared. Any ideas on what happened to it? Also, does anyone have a 2.2 ohm resistor that will be down at firestone tonight and if not anyone know where to get one? Already checked radio shack
  14. fino22
    fino22 New Member
    Blaine
    I believe I have one that I used when I deleted my EGT sensor on my uppipe, let me know if you need it and I can run it down to you when I am down on university
  15. MNAutomatic
    I'm on the westside
    I will definately take it if you have one. None of the radio shacks around me have the 2.2K Ohm 1/2 watt resistor that you need. I can take you for a ride tonight as well if you are gonna be at firestone for awhile
  16. fino22
    fino22 New Member
    Blaine
    what time do you plan on getting down there?
  17. MNAutomatic
    I'm on the westside
    I will get there around 8 or a little after prolly, and I'll stay till about 945ish or so. We'll see how the crowd is
