my custom cheapo bug protector
Discussion in 'Modifications And Maintenance' started by ej20, Jul 9, 2007.
  1. ej20
    ej20 Well-Known Member
    ok, I had enough of bug going into my intercooler and I though of this way to fix it. Bought some cheapo filter(ac filters) from Wal-mart and tried this. The only problem is that donnoe if its High Heat resistance. I've tried melting it with a Glue Gun and it doesn't melt but we'll see after driving it. Air goes through it perfectly. Donnoe about Rain though. What do you guys think?
  2. Sogonerg
    Sogonerg Anteater
    hmmmmm... r u sure your not blocking a whole lot of air from going in?
  3. Bielke55
    Bad Idea.... Your clogging the I/C worse then bugs...
  4. ej20
    what should I use then?
  5. Bielke55
    Water to wash the bugs off and let it be the way it was meant to be... its hot enough out. with a micro filter block your I/C
  6. Sogonerg
    Sogonerg Anteater
    nothing really...just rinse it off more often...
  7. Nuke
    I think you're really restricting the ammount of air that should be flowing into your IC.
    take it off and just make some sort of grille to block it
    or drive your car off a cliff.
  8. Sogonerg
    Sogonerg Anteater
    all I can suggest is putting a mesh in front of your hood scoop...but it won't be small enough for bugs not to go through...u definately don't want to screw with the air going to the I/C u don't want any cooling issues due to bugs!?!
  9. Bielke55
    Agreed /\..... Maybe some mesh screening (or fine chicken wire to be a cheapo about it) at the front of scoop as a grill...
  10. Sogonerg
    Sogonerg Anteater
    How about attaching a fly swatter in front of your hood scoop? ;)
  11. Bielke55
    Or a redneck bug zapper?
  12. ej20
    I still need to increase my auto insurance first........hahaha(hey, I need that K&N filter)
  13. gran0393
    gran0393 Well-Known Member
    redneck bug zapper inside the scoop would push a ricer look over the edge...imagine the glow!!!
  14. Sogonerg
    Sogonerg Anteater
    u know...if u could make a bug zapper work...man that might win invention of the year...lol
    It would be like a force field...haha
  15. 1_sic_rex
    1_sic_rex Well-Known Member
    Ha ha + 1 on the bug zapper.... maybe your car is hungry, yaknow... for bugs.. take that thing off and let it eat!!!!
  16. vanddelor
    vanddelor Well-Known Member
    you can alway put double sided sticky tape inside the scoop and bugs will just stick on that instead of going to your tmic...
  17. AWDimprezaL
    hang a couple of things of fly paper from your scoop.
  18. SUCKERPUNCH
    SUCKERPUNCH New Member
    Go to home depot, and get a section of gutter guard ($1.00). it's a steel mesh little bigger than chicken wire, cut it to shape then zip tie it to the scoop supports.
  19. gran0393
    i still vote bugzapper
  20. Dream
    I vote deal with bugs, you live in MN its going to happen.
  21. ej20
    ok, IT WAS A BAAAD IDEA.... This morning I forgot that I put that filter on my scoop and I drove it to NorthTown and realized that my accelleration is kinda slow and also, every time I shift theres a poor shift making the car shaky(like when you're just started learning to drive Manual). Got back home and notice that its that Bugie protector. Through it away and put my Cutted Intake Silencer on and torque kicks in fast at low RPM. ---stupid me----
  22. Bielke55
    live and learn.... it was a good try
  23. Sogonerg
    Sogonerg Anteater
    and potholes
  24. wraithpreza
    wraithpreza New Member
    Wrx-zapper
    lost many a rim to potholes..
    +1 on the bugzapper idea. so here it is.. the WRX-ZAPPER
