My keys wont come out.....
Discussion in 'Modifications And Maintenance' started by Ej22TIM, Aug 20, 2007.
  1. Ej22TIM
    Ej22TIM Well-Known Member
    MNSubaru B-Series Member #713
    i just got my auto to manual swap all buttoned up and i have 1 slight problem.
    my keys wont come out of the ignition...... has this happened to anyone before? is there a park sensor that i can hook up or something?
    Tim
  2. Speedemon
    Speedemon Well-Known Member
    at work...
    put the car in park...
  3. Speedemon
    at work...
    ohh i didnt read teh whole thing before i replied...i'm guessing you have it in park but they still wont come out?
  4. Bullwinkle
    Saint Paul
    Sounds like he swapped in a manual, so there is no park...
  5. Chux
    Independence, MN
    lawl
    yea...I had this problem. I managed to "override" it with a screwdriver and a hammer :biggrin:
    I'll consult my diagrams and whatnot and see what I can find. What car is this in?
  6. AWDimprezaL
    Monticello.
    T-leg 1993
  7. webcrawlr
    webcrawlr Well-Known Member
    minneapolis
    Reading skills > you :laugh:
  8. Dynapar
    Orono, MN
    Have you fixed up the park/neutral sensor on the auto wiring harness? IIRC you need to re-wire the harness slightly, essentially by-passing the P/N sensor so you can start the car w/o being in P/N this might also fix the issue of the keys not coming out.
  9. kickin_81
    kickin_81 Well-Known Member
    St. Paul
    Did you turn the steering wheel to the lock position with the car turned off and the key in the ignition? That will lock the key in position until you play with the steering wheel for a bit.
  10. angusracer
    angusracer Well-Known Member
    consider your car jacked ... by me. i just need to learn how to drive stick
  11. eagle talon guy
    Monticello
    there is a thread wit helpful hints! its called like my worst fear of newb driving or sumthing along those lines (im prolly way off!) haha
    someone correct me if im wrong.
    and sorry to change the subject.
  12. angusracer
    how does the finished product look? you should call me when you're in the area
  13. Chux
    Independence, MN
    looks like the key lock solenoid is controlled by pins 9 and 11 on the shift lock control unit, being Blue with red and Black with red respectively. and the plug at the solenoid is a 2 pin black connector. judging by the diagram, it looks like it needs a current through it (probably 12v+ through pin 9 and ground through 11, although it should work the other way around)
    I suspect the solenoid is on the steering rack. and I suspect that once you override it once, you won't have to do it again....
  14. Ej22TIM
    i have it so the ecu thinks its in neutral, which involved jumping one of the plugs from the auto trans. maybe i can wire it so it thinks its in park too?
    i will look in my manual for the shift lock solenoid. until then, im lockin the keys in the car with my spare lol
  15. Chux
    Independence, MN
    has nothing to do with the ECU....or the wires from the tranny...just 2 wires that go directly from the shift lock control unit to the key lock solenoid.
    the shift lock control unit is rather easy to find...larger unit (not as large as the ECU or TCU, but larger than a relay), and under the dash, and has a big sticker that says "shift lock" on it. I think I have one or 2 around here from my various swap harnesses....I'll see what I can find.
