Apparently using the jack handle as a lever is a bad idea. Snapped off both bolts on the caliper bracket. Can't source a new one until Thursday. If you have one around give me a text, I can pick up. thanks, Glen six-0n3-two-9nineone-3750
I was able to get the bolts out using a LOT of heat. I just need to get some new bolts and I should be ok. FYI, a wheel stud is the same size, if you need to put stuff back together to move the car around.
