Need Help 93 Honda Accord
Discussion in 'Off-Topic' started by billylee0000, Aug 13, 2008.
  1. billylee0000
    So long story short my gf's accord's hood won't close..It'll latch on but it won't close completely...i've been trying to close it for about an hour now...slamed it a few times.. adjusted the latch itself...nada...anyone know anything about this would be greatly appriciated:)
    NOTE: I would try the honda forums...but most of the time they're of no help...Plus i'm a mn subaru member ;)
  2. aspiringRexer
    aspiringRexer Member
    Slam it harder?
    Latches can get put in the closed position when they're still open, so it'll make the sound like it's closed, but it won't fully. Take a screwdriver and see if you can push anything on the latch out of the place where the bar pops in (essentially reset it to the open position).
  3. billylee0000
    i've been slamming it pretty hard lol...but yeah...did that and is still doing that...nothing so far
  4. TSTRBOY2004
    spray some penetrant in there... very common on hondas... most cars up here by the way.. soak the latch area down real good...
  5. billylee0000
    tried that as well...so far still nothing :(
  6. TSTRBOY2004
    hmmmm... check with a screwdriver that the latch arm is moving.. it may be stuck open.. again spray more in then move it back and forth... until it moves freely...
  7. TSTRBOY2004
    ps.. make sure your handle inside the car is back in... they can stick out and keep the latch open too...
  8. billylee0000
    IT LATCHED!!! OMFG FINALLY!!! so i sprayed it back down real good again..and then i readjusted the latch as well as the grill (pulled out the grill)... i dunno what i did, maybe it was just luck..but it worked...
  9. billylee0000
    thanks aspring and tstrboy for the quick responses...
  10. aspiringRexer
    I was going to come back and recommend you slam it really really hard, so I don't know if you should be thanking me. I almost broke your hood by proxy. :)
