Will anyone help me withan injector swap i had all of those problems with the old ones and now i got some to put in but i need help b/c last time i had LSE do it cause i didnt have the time/patience but now i know the car is being starved of fuel so i just need help putting them in. If anyone has done this and is possibly willling to help. I will pay but i am swamped for cash cause my clutch is going out and im doing a stage two...
Off topic questions.... I'm a bit confused. You had LSE Performance install injectors for you, and you're having fuel issues? What did you have them install? Stock wrx injectors are fine for a basic stage 2 set-up... Either way, what injectors do you plan to run and what EM are you currently using?
they took out the stockers, put in the Dworks, realized they were bad and swapped them back for the stockers. now he is gunna have my Helix injectors and running OpenECU for now
yep, unfortunate but it happens i guess. should be nice when he will have injector size for more than 10psi hold and 12 spike. lol
I'll be putting back my top feeds after they get back from cleaning and flow tested. Simple process....for me that is. lolz
