Need PC Computer Help.
Discussion in 'Off-Topic' started by wrxsti_02, Jul 9, 2012.
  1. wrxsti_02
    wrxsti_02 Well-Known Member
    Hi guys,
    Was wondering if any computer guys here that can help me diagnose my pc problem. My computer does not power up anymore. I thought it was the power supply so I replace it with a new one and still no power. I notice that if I unplug the power to the motherboard the fans and case light will come on but when I replug the the power to the motherboard (after shutting it down) the computer won't turn on. Does that mean a bad motherboard? Plz Help
  2. JasonoJordan
    Very good chance the mobo is shot. Unpug all drives take the ram n video card out and listen to see if the motherboard beeps(posts) if it do sent. Bad mobo.
  3. freeze2104
    freeze2104 Well-Known Member
    did you get it figured out? was there anything odd you noticed right before the issue? Jasono said it, that will help you pin point the issue.
  4. wrxsti_02
    Thanks guys for your help. Found mb is bad.
